Dmsee Posted October 2, 2008 Report Share Posted October 2, 2008 That one LOCKS the trunk, but does not UNLOCK it.WHat? Ill test it in a few minutes Link to comment Share on other sites More sharing options...
vegasjetskier Posted October 2, 2008 Report Share Posted October 2, 2008 WHat? Ill test it in a few minutes"Trunk lock" function Pressing this switch locks the trunk, even if the doors are unlocked. The trunk will remain locked even if the doors are locked/unlocked using the master key or the remote control. To use this function: · Turn the master key to position II. · Press the "trunk lock" button. An LED in the button will light up and a message will be displayed in the text window to indicate that this function is activated. · The function can be turned off (deactivated) by turning the ignition key to position II and pressing the "trunk lock" button again (the LED in the button will go out). * The position of this button may vary, depending on the specifications of your car. Link to comment Share on other sites More sharing options...
Young Burnsy Posted October 2, 2008 Report Share Posted October 2, 2008 if the car is unlocked. the button above the license plate should work no? Link to comment Share on other sites More sharing options...
Dmsee Posted October 2, 2008 Report Share Posted October 2, 2008 What would happen if you unlock the car with the key and then press the key button inside (lock unlock) I do that and it opens my trunk Link to comment Share on other sites More sharing options...
TurboS60 Posted October 2, 2008 Report Share Posted October 2, 2008 What would happen if you unlock the car with the key and then press the key button inside (lock unlock) I do that and it opens my trunkYea if you unlock the car by pressing the unlock button twice my trunk will unlock too. LoL Link to comment Share on other sites More sharing options...
matt1122 Posted October 3, 2008 Author Report Share Posted October 3, 2008 What would happen if you unlock the car with the key and then press the key button inside (lock unlock) I do that and it opens my trunkNot if you use the service key and don't have a key fob. Hence the purpose of the service key, to keep people out of the trunk and glove box.Thank you much for your suggestion though. Link to comment Share on other sites More sharing options...
vegasjetskier Posted October 3, 2008 Report Share Posted October 3, 2008 Not if you use the service key and don't have a key fob. Hence the purpose of the service key, to keep people out of the trunk and glove box.Thank you much for your suggestion though.Did you get it open? Link to comment Share on other sites More sharing options...
MrWinkey Posted October 3, 2008 Report Share Posted October 3, 2008 I don't quite understand how he locked the key in the trunk to begin with??? Link to comment Share on other sites More sharing options...
jhb8426 Posted October 4, 2008 Report Share Posted October 4, 2008 I don't quite understand how he locked the key in the trunk to begin with???My wife has done it twice. Stuff happens... <_< Link to comment Share on other sites More sharing options...
FistFull Posted October 5, 2008 Report Share Posted October 5, 2008 Has this been solved yet?....you already have 2 01 S60s on here did you open it? Link to comment Share on other sites More sharing options...
FistFull Posted October 5, 2008 Report Share Posted October 5, 2008 I just read this a day ago now my trunk won't open...I think its just stuck... Link to comment Share on other sites More sharing options...
FistFull Posted October 5, 2008 Report Share Posted October 5, 2008 Got it opened...... It was just jammed.... Link to comment Share on other sites More sharing options...
mustang Posted October 12, 2008 Report Share Posted October 12, 2008 I'm guessing you have this sorted out by now...Just did the same thing with my S80 while on vacation stranded with no phone...My options were to 1. tow it 70 miles to Volvo (locksmiths will not touch volvos...)2. rip the trunk door off3. pry up the speaker deck cover and feel around for the cable releas that connects directly to the back seat latch. I took option 3 (option 2 was a few minutes away) and I was able to lift the rear deck cover up a few inches and grab the cable to the back set behind the driver seat and a slight tug and the seat unlocked and folded down. I crawled in and got the keys. PS the alarm was going off so I removed the fuse (on the side of dash on the drivers side).Volvo... so well built, not even I could get in :( Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted October 13, 2008 Report Share Posted October 13, 2008 Sounds like the valet key is not programed. Order a Master key by code and have it programed at a later date. ;) Link to comment Share on other sites More sharing options...
