Cal3thousand Posted October 13, 2008 Author Report Share Posted October 13, 2008 You lucked out - those valves don't appear so bent - hopefully the guides are in reasonable shape.Awful lot of coking on the pistons/valves - what grade gas did you run? Ever use Techron? I run the good stuff... well... 91... good for being in cali. Usually pump 76 gas, but who knows that the previous owner put in it.I've used Chevron now and then too. Is that bad?And about all that gunk, how should I go about removing that? Link to comment Share on other sites More sharing options...
Keaton85 Posted October 13, 2008 Report Share Posted October 13, 2008 I run the good stuff... well... 91... good for being in cali. Usually pump 76 gas, but who knows that the previous owner put in it.I've used Chevron now and then too. Is that bad?And about all that gunk, how should I go about removing that?Its not that bad, just clean both mating surfaces and throw on the head gasket. DONE! Link to comment Share on other sites More sharing options...
Cal3thousand Posted October 13, 2008 Author Report Share Posted October 13, 2008 Its not that bad, just clean both mating surfaces and throw on the head gasket. DONE!Can I clean the tops of the pistons with anything? Link to comment Share on other sites More sharing options...
Keaton85 Posted October 13, 2008 Report Share Posted October 13, 2008 Can I clean the tops of the pistons with anything?sure, just bring them to TDC and take a raver blade to them with a little bit of solvent. Link to comment Share on other sites More sharing options...
Cal3thousand Posted October 13, 2008 Author Report Share Posted October 13, 2008 sure, just bring them to TDC and take a raver blade to them with a little bit of solvent.Ok... will do.Also, in that pic, I have the crank marked lined up the same way as I would when I reinstall. Does that look right? #4 TDC? Link to comment Share on other sites More sharing options...
lookforjoe Posted October 14, 2008 Report Share Posted October 14, 2008 Ok... will do.Also, in that pic, I have the crank marked lined up the same way as I would when I reinstall. Does that look right? #4 TDC?Make sure you get all the crud out from around the piston/cylinder wall when you clean off the piston - it will build up in the gap between the top piston ring & the landing - clean the pistons @ the top of each one's travel. I use scotch brite pads in a drill - much faster You should have the the crank TDC #1 - that's what the alignment marks are for... make sure your cams are aligned accordingly - use the plastic cover to align the cam gears if you don't have access to the Volvo tool (uses the notches on the sensor/distributor ends). Link to comment Share on other sites More sharing options...
