Compressed O2
  • Replies 76
Guest ATL t5m
Anti-lag system ALSO known as a WOT box.
Causes the car to misfire between shifts yada yada, also a wot box is good from a dig. IE you can set the WOT box at 4k RPMS, romp on the gas (stick cars) while clutch is not engaged in 1st gear and it will bounce off 4k rpms as if it was bouncing off the limiter, and this also creates boost so you can launch in boost.
Wouldn't having the clutch out not put any load on the engine, and thus not create boost, or at least not very much?
Guest ATL_t5m
The car misfires, creating a load on the engine therefore creating boost
Also no load on the motor does NOT mean it will not create boost. Bounce your car off the limiter in Neutral once and watch the boost gauge, you will hit roughly 6-8lbs on a tuned car.
Its what after burners on a jet are. You basically dump un burned fuel into the turbine and light it. You are not relying on exhaust gas per say, more like an explosion in the manifold.
That's gotta do wonders for the manifold and turbo's longevity :lol:
now theres an idea!
Guest ATL_t5m
Welcome to the world of hastalloy and inconel. Turbos are usually ok with it. Its more about the manifold.
Chuck me and friends been running WOT box's on cars for years and not a problem yet
Guest ALS_t5m
WOT boxes are not ALS. If anything they are closer to launch control than ALS.
I understand where your coming from but an ALS prevents comlete loss of boost between shifts right? So does a WOT box
