Compressed O2
  • Replies 76
Che knows his stuff. O2 is not flammable. We tried dumping it from a tank right into the carb of a VW, and it did raise the output a good bit untill the exhaust seats cracked from the heat (lean!) Do the math and add fuel and it should work fine.
That's what I was thinking, as long as its metered air and the ECU puts in the appropriate amount of fuel.
I mean, for a guy that has a crappy conical 15g still, a little extra boost on tap would be cool. Just conjecture as I would never pull that off.
So the air would have to pass the MAF unless you were running MAP
Ok. Here is the most important rules of white block tuning.
1. Its EASY to make more power than your rods will handle. No need for black magic here
2. With a built bottom its EASY to make more HP than the head supports
3. If you are here and dont have a clue yet, abandon all hope.
Guest ALS_t5m
MBCs do not alter boost pressure on shifts
It's not like many people on here have to shift anyway, people with autos on here think 5-spds don't lose boost between shifts like they don't
