Cal3thousand Posted October 7, 2008 Author Report Share Posted October 7, 2008 lame. tiny turbo to spool big turbo is where its at.Series turbos FTMFW Link to comment Share on other sites More sharing options...
kildea Posted October 8, 2008 Report Share Posted October 8, 2008 Series turbos FTMFWmy k27 spools up and my tune sucks right now, if you do all of the supporting mods and have a turbo that will produce an efficient air charge, with a decent intercooler you will enjoy your car. there may be some lag in the lower gears, but tuning can help a lot, and if the air remains cool in the top end your "20 psi" will yield more power, the intercooler helps, but a better compressor with a better intercooler helps more, with a good free-flowing exhaust and a cool air charge the boost will be better when it hits, and keeping the rpms above 2600 or so when shifting is easy enough if you have a manual.i think you just need to do the initial work that all whiteblocks benefit from: bigger exhaust, decent header, bigger turbine (do what you want with the compressor to keep it efficient, less backpressure helps a lot too i have an 80mm turbine and it spools), ebay intercooler, tune. if these are done then cams, head work, etc. the rods are a weak link, but i think some people bend them because of a shitty tune and a hot air charge. Link to comment Share on other sites More sharing options...
