Koni Diy Coilovers
bmx9854
8" 425lb springs? You better get your fillings reinforced. I have 8" 350lb springs. I couldnt imagine any stiffer. I may buy 300 lb springs.
Gary
:o What do you mean by fillings reinforced? The reason I went with #425 probably wasn't for the best decision, they were half the price of all the rest of the springs. I was going to go with #550. Maybe you can show me a pic of the fillings.
  • Replies 82
:lol: :lol: :lol: :lol: He means the fillings in your teeth!! :lol: :lol: :lol: :lol:
he means the fillings for your teeth, because the ride will be so stiff it'll knock all your teeth fillings out. there's a science to matching spring rates, heights and dampening forces. you might want to look into what you're actually doing instead of buying for pure price point.
Im using 10" 475 springs on my Koni coilovers. The ride is stiff but still quite comfy. The longer spring helps the ride a bit.
Ben
I imagine the 10" 475lb is probably a little more forgiving then the 8"/ If I was that guy, I would change my order to either a 10" 475lb spring or a lighter weight 8".
Gary
Ok...
First of all, that spring rate with the koni's you are asking for trouble if you race. As far as I can tell you are overwhelming the valving on the koni's with that stiff and low of a spring. There is some geometry involved here.
What you need to do is talk to toweryMT on tbricks. Or even search tbricks for information. It has been covered extensively.
Also... any sleeve will work, you just have to take some material off the strut body. As long as you don't jeopardize the integrity of the strut you should be fine.
You don't wan't too stiff... you will have more issues with suspension than you know how to fix/deal with. Just my 2 cents... check tbricks for infor about spring rates and the valving on different struts.
