TorqueSteer Posted October 10, 2008 Report Share Posted October 10, 2008 Ok...First of all, that spring rate with the koni's you are asking for trouble if you race. As far as I can tell you are overwhelming the valving on the koni's with that stiff and low of a spring. There is some geometry involved here.What you need to do is talk to toweryMT on tbricks. Or even search tbricks for information. It has been covered extensively.Also... any sleeve will work, you just have to take some material off the strut body. As long as you don't jeopardize the integrity of the strut you should be fine.You don't wan't too stiff... you will have more issues with suspension than you know how to fix/deal with. Just my 2 cents... check tbricks for infor about spring rates and the valving on different struts.I see where you are coming from. For street use though, I think my setup does a great job: 10" 475# springs. I had to perform an emergency "get out of the way" procedure on the highway at about 80mph the other week, and I was amazed at how stable the car was at that speed. Link to comment Share on other sites More sharing options...
550 Posted October 10, 2008 Report Share Posted October 10, 2008 Oh no doubt hehe. With 10 inch springs you are better. There is more travel. With an 8 inch spring it will not only be VERY low you will not have as much travel.You have Koni adjustables? Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted October 10, 2008 Report Share Posted October 10, 2008 can we get some pictures of 8" vs. 10" setup ride heights? how low are we talking? Link to comment Share on other sites More sharing options...
550 Posted October 10, 2008 Report Share Posted October 10, 2008 Well maybe not low being such an issue... but bottoming out the insert possibly. As for pics... I have none :-/ You can see different setups on tbricks with a little searching. Since they are such a high # it may not even be an issue. But with the valving on the Koni's I don't know how they will work out with those high spring rates.http://www.kaplhenke.com/index.php?option=...2&Itemid=32Shortened inserts... may be the answer. Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 10, 2008 Report Share Posted October 10, 2008 Oh no doubt hehe. With 10 inch springs you are better. There is more travel. With an 8 inch spring it will not only be VERY low you will not have as much travel.You have Koni adjustables?Absolutely, I had the lowboyz coilovers with 8" springs and I was bottoming out ALOT. I now have the Koni adjustable based coilvers. I have that first set that GT2 made, the one used to make the DIY. Heres a pic of the lowest you can go with the 10" springs. Keep in mind that the tires are pretty skinny, some 45 profile tires will fill out the wheel well nice. Any lower and you will run into problems with speed bumps and inclines, trust me...ive been there and its not fun. Link to comment Share on other sites More sharing options...
Markymark Posted October 10, 2008 Report Share Posted October 10, 2008 Can i do this with the koni FSD's i have in right now? the rears are okay, its just the front that is too high for my liking. Mark Link to comment Share on other sites More sharing options...
Yellow95 Posted October 10, 2008 Report Share Posted October 10, 2008 This is the DIY konis with 8" 350lb springs at about 1/2 drop (14 turns from the top). I dont know how low it can go as I like it exactly where it is.Gary Link to comment Share on other sites More sharing options...
PhilippineT5 Posted October 11, 2008 Report Share Posted October 11, 2008 when i do mine, i dont want any space between the tire and the fender, not even half a finger :D Link to comment Share on other sites More sharing options...
Chilled man Posted October 11, 2008 Report Share Posted October 11, 2008 hmmmm not sure if its worth it Link to comment Share on other sites More sharing options...
PhilippineT5 Posted October 11, 2008 Report Share Posted October 11, 2008 the best set-up i think is to use 8" springs & a 2" progressive spring for better ride quality.. what you guys think? Link to comment Share on other sites More sharing options...
bmx9854 Posted October 11, 2008 Author Report Share Posted October 11, 2008 the best set-up i think is to use 8" springs & a 2" progressive spring for better ride quality.. what you guys think?Where did you get the 2" spring from and is that other thing a c/o nut in between the 2" and 8" spring? Link to comment Share on other sites More sharing options...
mune237 Posted October 11, 2008 Report Share Posted October 11, 2008 What are you guys doing for the rear? Link to comment Share on other sites More sharing options...
green machine Posted October 11, 2008 Report Share Posted October 11, 2008 dose anybody know where i can get a sleve for the blistiens ? or what i need to be looking for size and all ? Link to comment Share on other sites More sharing options...
DARKSIDE Posted October 11, 2008 Report Share Posted October 11, 2008 when i do mine, i dont want any space between the tire and the fender, not even half a finger +1 Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 11, 2008 Report Share Posted October 11, 2008 What are you guys doing for the rear?In the rear I have bilstein HD shocks with Hypercoil 5.5" x11" 375# springs. stockcarproducts.com part number 18SN375 Link to comment Share on other sites More sharing options...
