PhilippineT5 Posted October 12, 2008 Report Share Posted October 12, 2008 Where did you get the 2" spring from and is that other thing a c/o nut in between the 2" and 8" spring?i found it laying around in the old stock stuff.. the thing in between the 8" & 2" spring is the aluminum seperator.. its not threaded.i think this set up would be good in terms of drop and ride quality ;) Link to comment Share on other sites More sharing options...
550 Posted October 12, 2008 Report Share Posted October 12, 2008 There are a couple of things you can do for the rear. 1. Run 5.5 inch dia. springs. Easy, and cheaper.2. Run 2.5 inch dia. springs with a cup and perch like KW's. Not that much more money than option number 1.3. Run a full blown coilover in the rear. Some notes about that include... You may not want to use the original lower shock mount. (or upper for that matter) You will probably need to fab a bit. :-/ It is a little easier in the older cars (240's) but the newer cars make it a little difficult. Link to comment Share on other sites More sharing options...
nari Posted October 12, 2008 Report Share Posted October 12, 2008 2. Run 2.5 inch dia. springs with a cup and perch like KW's.where to get those?I couldn't find any hardware for the back. Link to comment Share on other sites More sharing options...
Gioseppe Posted October 12, 2008 Report Share Posted October 12, 2008 where to get those?I couldn't find any hardware for the back.you can order spring perches directly from koni for the fronts, to then use with either the stock spring mount or a camber plate setup if you had them, although at that point one should check out vorschlag (upper) spring perches.what hardware are you thinking of for the back? if you get a 5.5" single pigtail spring, 11" long, then you shouldn't need any other hardware, it replaces the stock spring... if you want lower, you can cut the spring.If you want adjustability, then you would have to find (or fab, by all means ) a sleeve that would bolt to the suspension arm and have a 5.5" threaded collar. stock rear upper spring mounts work perfect. Link to comment Share on other sites More sharing options...
550 Posted October 13, 2008 Report Share Posted October 13, 2008 You can call stockcarproducts.com and they should have them. Adjustable spring perches for the rear.But like Gioseppe said... 5.5 inch springs with some cuttage and you are golden. Link to comment Share on other sites More sharing options...
nari Posted October 13, 2008 Report Share Posted October 13, 2008 If you want adjustability, then you would have to find (or fab, by all means ) a sleeve that would bolt to the suspension arm and have a 5.5" threaded collar. stock rear upper spring mounts work perfect.thats what I was talking about... few months ago someone tried to sell a pair of rear perches for the rear (KW) from a wrecked 850.. I missed that You can call stockcarproducts.com and they should have them. Adjustable spring perches for the rear.But like Gioseppe said... 5.5 inch springs with some cuttage and you are golden.thanks!mehh, I don't want to cut springs. that messes up the spring #-s Link to comment Share on other sites More sharing options...
550 Posted October 13, 2008 Report Share Posted October 13, 2008 Actuallllllly, it will only really mess up the spring rate if the springs are progressive.http://forums.turbobricks.com/showthread.php?t=150091By the way... post number 16 is the winnar. Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 13, 2008 Report Share Posted October 13, 2008 The 11 inch high springs im using are lower than any other lowering spring. No hardware needed, just buy them and slip them in. If you want to go lower, you can cut a coil and it will still ride fine. Or look for a 5.5 x 9 inch spring Link to comment Share on other sites More sharing options...
PsychoBeano Posted October 13, 2008 Report Share Posted October 13, 2008 The 11 inch high springs im using are lower than any other lowering spring. No hardware needed, just buy them and slip them in. If you want to go lower, you can cut a coil and it will still ride fine. Or look for a 5.5 x 9 inch springYou think you can post a picture of your stance as it is now? I saw the picture of just the front but I would like to see your rear. Last time I remember seeing that is when you cut the rears a little? Are those the springs you still have in the back? Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 14, 2008 Report Share Posted October 14, 2008 You think you can post a picture of your stance as it is now? I saw the picture of just the front but I would like to see your rear. Last time I remember seeing that is when you cut the rears a little? Are those the springs you still have in the back?Yeah this what I used to have, 11 inch springs cut 1.5 coils...way too low for a daily.Ill get some pics up tommorow of whats on there now. It dosent seem so low anymore compared to these pics! Link to comment Share on other sites More sharing options...
bmx9854 Posted October 14, 2008 Author Report Share Posted October 14, 2008 Did you roll your fenders? Link to comment Share on other sites More sharing options...
550 Posted October 14, 2008 Report Share Posted October 14, 2008 I'm pretty sure he had to roll his fenders with the car being that low. Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 14, 2008 Report Share Posted October 14, 2008 Did you roll your fenders?Absolutely! Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 14, 2008 Report Share Posted October 14, 2008 Heres how it sits now with the 10" 475# springs in the front on Koni coilovers, and 5.5x11" 375# springs in the rear. Link to comment Share on other sites More sharing options...
bmx9854 Posted October 15, 2008 Author Report Share Posted October 15, 2008 What size wheels and tires are you running? Link to comment Share on other sites More sharing options...
