9883 Posted October 11, 2008 Report Share Posted October 11, 2008 I got one and was told that it's an 850 R but not sure. Link to comment Share on other sites More sharing options...
Hoosier Daddy Posted October 11, 2008 Report Share Posted October 11, 2008 if it's an R ecu it will have the numbers 628 at the end of the long bosch serial number. the standard 850 turbo ecu ends in 072 Link to comment Share on other sites More sharing options...
9883 Posted October 12, 2008 Author Report Share Posted October 12, 2008 if it's an R ecu it will have the numbers 628 at the end of the long bosch serial number. the standard 850 turbo ecu ends in 072I know that. I'm talking about T5R only made in 95 and 96-97 850 R, not T5. Link to comment Share on other sites More sharing options...
Hoosier Daddy Posted October 12, 2008 Report Share Posted October 12, 2008 no idea. is there a diff? Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted October 13, 2008 Report Share Posted October 13, 2008 no idea. is there a diff?Yes, EGR in 1995. Bosch numbers are the same. You will need to know what year it came out of. Link to comment Share on other sites More sharing options...
Deathshead Posted October 14, 2008 Report Share Posted October 14, 2008 Yes, EGR in 1995. Bosch numbers are the same. You will need to know what year it came out of.Speaking of R ecus, just how much different is the tuning on the R's? its just just a turbo ECU with 2 extra PSI? Or does boost comin alot earlier?With the stock turbo tune, my car is really lazy until its movin. Link to comment Share on other sites More sharing options...
Wagoneer855 Posted October 14, 2008 Report Share Posted October 14, 2008 With the stock turbo tune, my car is really lazy until its movin.Lots of ways to fix that. Link to comment Share on other sites More sharing options...
EricF Posted October 14, 2008 Report Share Posted October 14, 2008 Speaking of R ecus, just how much different is the tuning on the R's? its just just a turbo ECU with 2 extra PSI? Or does boost comin alot earlier?With the stock turbo tune, my car is really lazy until its movin.Your car's situation is more than likely a factor of wastegate actuator arm preload not being within spec. In any case, you should be able to improve responsiveness by tightening the actuator arm a couple of turns. If you search around there should be some posts detailing how this is done.In terms of ECU differences, it might just be a boost difference, but I suspect the ignition timing is a little bit more aggressive on the R cars as well. Keep in mind that the R cars in every other market got bigger injectors and a more efficient turbo. Link to comment Share on other sites More sharing options...
