gutbusterman Posted October 20, 2008 Report Share Posted October 20, 2008 I have a 96 850R and am looking to buy snow tires. I am currently running the 17" Volans, but I will be getting a set of 16" rims and I need to know what tire sizes will fit. I see the stock size is 205/50/16, but how far from that can I go? Will a 215/50 work or even a 215/55/16? What have you guys found that will work? Thanks. Link to comment Share on other sites More sharing options...
AlvinL Posted October 20, 2008 Report Share Posted October 20, 2008 I have a 96 850R and am looking to buy snow tires. I am currently running the 17" Volans, but I will be getting a set of 16" rims and I need to know what tire sizes will fit. I see the stock size is 205/50/16, but how far from that can I go? Will a 215/50 work or even a 215/55/16? What have you guys found that will work? Thanks.Double check your manual. My OEM snows are 195's on 15 inch with the Volvo caps. If you get a lot of the deep stuff, then go with Volvo's recommendation of 195 wide. You'll like leaving the rest of them behind when the light turns green when the tires grip well. Link to comment Share on other sites More sharing options...
Black Betty Posted October 20, 2008 Report Share Posted October 20, 2008 215 wont work as well as a 205 contray to popular belief you want the most lbs per square feet so you need to reduce the contact patch to do this. This applies in deep snow and ice. stay with the 205/50 Link to comment Share on other sites More sharing options...
gutbusterman Posted October 20, 2008 Author Report Share Posted October 20, 2008 215 wont work as well as a 205 contray to popular belief you want the most lbs per square feet so you need to reduce the contact patch to do this. This applies in deep snow and ice. stay with the 205/50Great point. I was too worried about what will fit that I neglected to think about that, the skinnier tires will bite better in the snow. Thanks. If I end up with 15" Rims, I'll go with 195's, but I am pretty sure I'll be stickin with the 16" I have lined up. Link to comment Share on other sites More sharing options...
Guest BJC Posted October 20, 2008 Report Share Posted October 20, 2008 Great point. I was too worried about what will fit that I neglected to think about that, the skinnier tires will bite better in the snow. Thanks. If I end up with 15" Rims, I'll go with 195's, but I am pretty sure I'll be stickin with the 16" I have lined up.Go with 205/55/16, they will work fine and there is a lot of choice in that size. Link to comment Share on other sites More sharing options...
Black Betty Posted October 20, 2008 Report Share Posted October 20, 2008 Go with 205/55/16, they will work fine and there is a lot of choice in that size.no they will rub on his Rget 205/50/16 i had a shop sell me 205/55/16 for my R when i first bought it. That size is correct for all 850's except for the R's. My fender liner was worn out and damaged by the larger size Link to comment Share on other sites More sharing options...
sconeman Posted October 20, 2008 Report Share Posted October 20, 2008 actually 195/55 16 would be better for snow traction and will fit fine (.37 inches larger in diameter) but will compromise cornering slightly. Link to comment Share on other sites More sharing options...
DonutsDemise Posted October 20, 2008 Report Share Posted October 20, 2008 wasn't the OEM size 205/55R16? they were on my T5, my NA had 195/60R15s which is closer to 205/50R16 though. Link to comment Share on other sites More sharing options...
Black Betty Posted October 20, 2008 Report Share Posted October 20, 2008 wasn't the OEM size 205/55R16? they were on my T5, my NA had 195/60R15s which is closer to 205/50R16 though.believe it or not s70s have larger wheel wellsactually 195/55 16 would be better for snow traction and will fit fine (.37 inches larger in diameter) but will compromise cornering slightly.Im not sure you want to put a tire that skinny on any of volvos 16" rims though might be pushing it. Link to comment Share on other sites More sharing options...
sconeman Posted October 20, 2008 Report Share Posted October 20, 2008 believe it or not s70s have larger wheel wellsIm not sure you want to put a tire that skinny on any of volvos 16" rims though might be pushing it.that's what's on my 16" rims for winter. good for snow, not good for performance though. Link to comment Share on other sites More sharing options...
AlvinL Posted October 20, 2008 Report Share Posted October 20, 2008 believe it or not s70s have larger wheel wellsTrue. Link to comment Share on other sites More sharing options...
betterthingstodo Posted October 21, 2008 Report Share Posted October 21, 2008 From my owners manual:Volvo recommends 185/65 R15 winter tires on 15" wheels on all 850 models including models equipped with 16" or 17" wheels. Link to comment Share on other sites More sharing options...
DonutsDemise Posted October 21, 2008 Report Share Posted October 21, 2008 believe it or not s70s have larger wheel wellsah so but does that mean that the OEM tire size was 205/50R16 on 850s? that and 55 sidewall are listed for mine but my old tires were 55s so I just assumed Link to comment Share on other sites More sharing options...
TM850R Posted October 21, 2008 Report Share Posted October 21, 2008 ah so but does that mean that the OEM tire size was 205/50R16 on 850s? that and 55 sidewall are listed for mine but my old tires were 55s so I just assumedhttp://volvospeed.com/Repair/2055516.php205/50/16 is OEM tire size on 850's. Link to comment Share on other sites More sharing options...
AlvinL Posted October 21, 2008 Report Share Posted October 21, 2008 From my owners manual:Volvo recommends 185/65 R15 winter tires on 15" wheels on all 850 models including models equipped with 16" or 17" wheels.That's it! That's what I have. Link to comment Share on other sites More sharing options...
