turbomoose Posted October 31, 2008 Author Report Share Posted October 31, 2008 OK! SO! I have replaced my control arms, wheel bearings, and endlinks this afternoon / evening ...And I still have the exact same noise! :angry: Guess who's making a service appointment with his local Volvo dealer tomorrow??ME!My stabiliser bar is still under warranty by a month, so I HOPE it's that. Link to comment Share on other sites More sharing options...
Scootdiggity Posted October 31, 2008 Report Share Posted October 31, 2008 OK! SO! I have replaced my control arms, wheel bearings, and endlinks this afternoon / evening ...And I still have the exact same noise! :angry: Guess who's making a service appointment with his local Volvo dealer tomorrow??ME!My stabiliser bar is still under warranty by a month, so I HOPE it's that.My friend had a similar problem and it was the rack going bad. My other friend had a similar problem and it was the inner and outer tie rods. Probably will be what the dealer diagnoses. If your car has around 150k I almost guarantee it is the rack starting to go bad. I have seen them start to go bad around that mileage. I also read in your first post introducing your car you went with aftermarket axles as well, you may need to use that metal adhesive on splines, even though I dont recommend it. Link to comment Share on other sites More sharing options...
xallenx Posted October 31, 2008 Report Share Posted October 31, 2008 HEY DAVIT So I get home from work and decide to take pics of that cross bolt. AND to make sure it's still tight. WELL. It wasn't tight, but snug.SO I removed everything, cleaned up the threads, got my tools and made sure it'd never back out on its own again. This was the reason why I was having suspension rattles over bumps. But this didn't fix my current noise. So double check yours. It may be loose. Wait!!! you can take the top nut and the cross shape nut out without compressing the springs?? I thought you can't do that. Link to comment Share on other sites More sharing options...
erikv11 Posted October 31, 2008 Report Share Posted October 31, 2008 Wait!!! you can take the top nut and the cross shape nut out without compressing the springs?? I thought you can't do that.you can always take the top nut off, the cross shape nut holds it together.you shouldn't take the cross nut off with the strut assembly out of the car. the spring will decompress and kill you or take your arm off etc. really.when the strut assembly is in the car, the top of the strut tower (that painted cap, welded onto the body) keeps the spring from decompressing. I suppose if the weld failed you'd lose your face.I would rather not unscrew the cross shape nut with the assembly in the car because on a strut job when you tighten it down for reinstallation, the spring is supposed to be compressed a certain length. Unscrewing it in the car means the weight of the car determines the spring compression (length), not a measurement. That may be just fine but I don't know, would rather not guess. Link to comment Share on other sites More sharing options...
turbomoose Posted October 31, 2008 Author Report Share Posted October 31, 2008 My friend had a similar problem and it was the rack going bad. My other friend had a similar problem and it was the inner and outer tie rods. Probably will be what the dealer diagnoses. If your car has around 150k I almost guarantee it is the rack starting to go bad. I have seen them start to go bad around that mileage. I also read in your first post introducing your car you went with aftermarket axles as well, you may need to use that metal adhesive on splines, even though I dont recommend it.My rack was replaced at the Volvo dealer, with a Volvo part at 70K for leaks. I don't think it's the rack, at least I hope it's not. Link to comment Share on other sites More sharing options...
Guest Guest_whilst_* Posted October 31, 2008 Report Share Posted October 31, 2008 My rack was replaced at the Volvo dealer, with a Volvo part at 70K for leaks. I don't think it's the rack, at least I hope it's not.[/quoteHi. Try greasing your steering stops well.HTH,Jeff. Link to comment Share on other sites More sharing options...
turbomoose Posted October 31, 2008 Author Report Share Posted October 31, 2008 It doesn't make the noise at full lock, but at any intermediate position. So it's not the steering stops.Car's been dropped off at the dealer, I doubt they've even looked at it. Link to comment Share on other sites More sharing options...
mkc70 Posted October 31, 2008 Report Share Posted October 31, 2008 Thought about replacing your sub frame bushings yet? I've read numerous posts on s80's with an o ring fix for this noise. Perhaps you have a similar issue. Link to comment Share on other sites More sharing options...
turbomoose Posted October 31, 2008 Author Report Share Posted October 31, 2008 Thought about replacing your sub frame bushings yet? I've read numerous posts on s80's with an o ring fix for this noise. Perhaps you have a similar issue.I have all 4 new subframe bushings. I've had to have my subframe replaced a few months ago. Link to comment Share on other sites More sharing options...
turbomoose Posted October 31, 2008 Author Report Share Posted October 31, 2008 Well, I went to the dealer after work, They're completely useless, but they're going to replace my stabiliser bar. And they're going to give it a 4 wheel alignment and it's 5K service since I'm about 600 miles shy of the service light coming on again.I'll keep you posted when I get my car back!Now it's '06 S40 2.4i of non turbo boredom with a dull grey interior and disgusting silver paint loaner car. <_< <_< Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 3, 2008 Report Share Posted November 3, 2008 Well, I went to the dealer after work, They're completely useless, but they're going to replace my stabiliser bar. And they're going to give it a 4 wheel alignment and it's 5K service since I'm about 600 miles shy of the service light coming on again.I'll keep you posted when I get my car back!Now it's '06 S40 2.4i of non turbo boredom with a dull grey interior and disgusting silver paint loaner car. <_< Any update Nathan? so is it at the top of the strut tower or not? mine is at the strut tower and this is keeping me from starting my upgrade Link to comment Share on other sites More sharing options...
turbomoose Posted November 3, 2008 Author Report Share Posted November 3, 2008 No, I still have the loaner. And my noise was definitely from under the car. Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 3, 2008 Report Share Posted November 3, 2008 No, I still have the loaner. And my noise was definitely from under the car.shit Link to comment Share on other sites More sharing options...
turbomoose Posted November 4, 2008 Author Report Share Posted November 4, 2008 Well my car is ready to be picked up. Finally. And free of charge since it was a warranty issue! That news was a complete shock, but makes me VERY happy. ...They'd better wash my car and make sure it doesn't look like it's been through a sand storm with the windows left down. Going to get it in a few hours. :) :) Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 4, 2008 Report Share Posted November 4, 2008 Well my car is ready to be picked up. Finally. And free of charge since it was a warranty issue! That news was a complete shock, but makes me VERY happy. ...They'd better wash my car and make sure it doesn't look like it's been through a sand storm with the windows left down. Going to get it in a few hours. :) so you going to tell us what exactly they found out was the creaking noise if it was coming from under the car or at the top of the strut tower? Link to comment Share on other sites More sharing options...
