bdimag Posted October 27, 2008 Report Share Posted October 27, 2008 if your amp supports it: some of them have speaker level inputs... so you could slice right into your rear speakers through the trunk... then you'd only have to worry about running a power cord...either that or yes, you could get a line-level adapter and then splice that in, also from the rear speakers through the trunk... Link to comment Share on other sites More sharing options...
volvoskiah Posted October 28, 2008 Author Report Share Posted October 28, 2008 Look at the back of your HU. Most Volvo decks have an amp connectionIf it has a 6 pin DIN jack marked "AMP", you can use a DIN to RCA adapter cable and go right into the amp, (including a remote on lead). Uber clean hook-up. So if i were to go this way, I do have the spot marked amp, I would just have to run a cord all the way to the trunk then go straight to the amp? What is a din to rca adapter? Link to comment Share on other sites More sharing options...
HayaCruza Posted October 28, 2008 Report Share Posted October 28, 2008 What is a din to rca adapter?Lets see if this helps. DIN is a multi-pin connector typically round that makes for easy connection of multiple wires (S-Video cable is similar).RCA is a far more common connection used in audio and video systems.Try this picture, this is just an example of a DIN to RCA adapter cable.... Link to comment Share on other sites More sharing options...
volvoskiah Posted October 28, 2008 Author Report Share Posted October 28, 2008 That makes sense. so if i just got that and ran wires to the trunk, it would hook up to the amp and the subs should work no problem? I only want to keep the stock head unit because it looks clean and goes with the styling of the car. Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted October 28, 2008 Report Share Posted October 28, 2008 Def Go With An AfterMarket Amp...If You Don't Want To Mess With Your Headunit Try Looking Up CleanSweep I Am Not Sure If They Have Them For Volvos But It Allows You Yo Convert Your Stock Headunit To An Aftermarket Setup..So You Can Install Subs...Good Luck! Link to comment Share on other sites More sharing options...
BEJinFBK Posted October 28, 2008 Report Share Posted October 28, 2008 Here ya go!http://www.quickbrickmotorsports.com/prod_....html#amp_cable Link to comment Share on other sites More sharing options...
volvoskiah Posted October 29, 2008 Author Report Share Posted October 29, 2008 Here ya go!http://www.quickbrickmotorsports.com/prod_....html#amp_cableThanks! I am going to order this and a two channel amp. I believe that would be everything I need.Def Go With An AfterMarket Amp...If You Don't Want To Mess With Your Headunit Try Looking Up CleanSweep I Am Not Sure If They Have Them For Volvos But It Allows You Yo Convert Your Stock Headunit To An Aftermarket Setup..So You Can Install Subs...Good Luck!Thanks! Link to comment Share on other sites More sharing options...
crazykn Posted October 29, 2008 Report Share Posted October 29, 2008 Click the link in my signature, its a DIY for how to make this adapter for cheap! Link to comment Share on other sites More sharing options...
SSCustoms Posted November 6, 2008 Report Share Posted November 6, 2008 you all fail, if you get an rca/wire adapter, u can saulder into the rear speakers, and the rca cable plugs into that little box, than into ur amp, than the subWhat do you know about stereos? Anything you get I am going to be suckered into installing anyway!!!Sup, James? :P Link to comment Share on other sites More sharing options...
cr854r Posted November 6, 2008 Report Share Posted November 6, 2008 What do you know about stereos? Anything you get I am going to be suckered into installing anyway!!!Sup, James? haha whats up scott, btw i installed it all myself... yes very gehto an took me like a week... literally... SORRY to bogart this thred. Link to comment Share on other sites More sharing options...
