bagodoosh Posted October 28, 2008 Report Share Posted October 28, 2008 so i have been studying this diagram:last time i did a flush, i put a garden hose in the reservoir with the water flowing and had the radiator drain unplugged; ran the car for a few minutes until steaming water started coming out of the radiator.however, looking at this picture, it seem that the lower hose is the main coolant feed - with the radiator drain unplugged, the majority of the flow from the reservoir would just drain thru the metal pipe on the back of the engine (#7), down thru the lower radiator hose (#13) and out the drain hole.i'm thinking the best method to flush the entire system during a radiator swap would be to remove the thermostat (#1c), open the up upper radiator hose (#12) for drain and clip the lower radiator hose (#13) so that the fresh water from the reservoir (#10) flows thru #17 to #7 and into the engine.any thoughts? Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted October 28, 2008 Report Share Posted October 28, 2008 So this is specifically for a radiator swap, and not actually as a cleaning procedure? IE you want all the coolant out before you bring it in your garage?Put a bucket under the lower radiator hose, unclamp it and back it off with a screw driver. Problem solved FYI, theres a drain hole on the back of the block as well. On the backside near pipe number 7. Link to comment Share on other sites More sharing options...
bagodoosh Posted October 28, 2008 Author Report Share Posted October 28, 2008 ya, i'm aware of the drain on the engine block. i have done the simple drain and re-fill before.this time i'd like to properly get clear water flowing thru the engine without starving it.so yes, it's for a cleaning procedure; it's because of a leak in the radiator which i have to replace - i have some sort of contamination in the cooling system. Link to comment Share on other sites More sharing options...
