MeanGreenSwedeMachine Posted October 29, 2008 Report Share Posted October 29, 2008 I developed a coolant leak recently (just noticed it today when my light came on). I immediately topped it off, and its deffinitely leaking somewhere, but even when the coolant is above the min line, the light stays on. Any reason for this? Link to comment Share on other sites More sharing options...
Chilled man Posted October 29, 2008 Report Share Posted October 29, 2008 the level sensor is broken get a a new OEM resivor problem solved dont get a FCP one ask adam or nathan about that junk :lol: Link to comment Share on other sites More sharing options...
Oreo931 Posted October 30, 2008 Report Share Posted October 30, 2008 dont get a FCP one ask adam or nathan about that junk Nothing happened to mine yet FYI.Also, it is probably your Coolant level sensor, you might not need a whole new reservoir. Before you order a new coolant level sensor, make sure the float in your current reservoir isnt broken. If it is, you need a new reservoir. Link to comment Share on other sites More sharing options...
AlvinL Posted October 30, 2008 Report Share Posted October 30, 2008 +1 on the float. You can see the float. If it's below the water line, give the bottle a tap. Maybe it's stuck to the bottom? Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted October 30, 2008 Author Report Share Posted October 30, 2008 Thanks guys.So theoretically, as long as I know that there's coolant in there, this could wait until say Thanksgiving when I go home? Or does the thermostat or something behave differently if it thinks there's no coolant? Link to comment Share on other sites More sharing options...
echristodo Posted October 30, 2008 Report Share Posted October 30, 2008 Thanks guys.So theoretically, as long as I know that there's coolant in there, this could wait until say Thanksgiving when I go home? Or does the thermostat or something behave differently if it thinks there's no coolant?Tstat will respond to temperature changes only, its purely mechanical. You are good, just follow everyone's directions! Link to comment Share on other sites More sharing options...
MavericK41 Posted November 3, 2008 Report Share Posted November 3, 2008 like the guys above stated, check the float. My coolant light had been on for a while with the coolant level being at max and the car never overheating so i figured that might be my problem. Went ahead and checked it out tonight and poked around in the coolant reservoir tank to try and move the float and the light went away. seems to have fixed the problem. Link to comment Share on other sites More sharing options...
