jnderr Posted November 3, 2008 Report Share Posted November 3, 2008 I noticed in the past week or so I've been losing coolant. Finally got under the car today to see where it was leaking from. It seems to be a fairly slow leak. I filled it up to max line on the coolant tank yesterday and its probably about an inch below that line now. One drip every 5 minutes or so. It is the bottom, passenger side of the radiator and does not appear to be leaking from the line that is connected there. But seems to be coming from where the black plastic on the end meets the metal.Judging from this pic is my radiator toast? Are there other steps I can take to further diagnose it?Thanks everyone in advance. Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 3, 2008 Report Share Posted November 3, 2008 ok, 1st of all... how old is your radiator?have you ever had it replaced?what color is the coolant that you put into your car?I had a similar leak and it happened when I screwed the upper radiator hose to the radiator too tight and separated the insides of the radiator from the plastic and metallooks like you might need a new one :( Link to comment Share on other sites More sharing options...
jnderr Posted November 3, 2008 Author Report Share Posted November 3, 2008 171k miles on the car. I bought it with 110k, I assume its the original. Have red coolant same as the drop you see there. Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 3, 2008 Report Share Posted November 3, 2008 171k miles on the car. I bought it with 110k, I assume its the original. Have red coolant same as the drop you see there.yeah, looks like your radiator is separating the plastic to the metal ends if you have the time it is an easy replacement Link to comment Share on other sites More sharing options...
cn90 Posted November 3, 2008 Report Share Posted November 3, 2008 At your mileage of 170K miles, do all of these for the sake of safety:- Radiator- Radiator Hoses x2- Small hose to Reservoir- Reservoir- Thermostat Link to comment Share on other sites More sharing options...
jnderr Posted November 3, 2008 Author Report Share Posted November 3, 2008 At your mileage of 170K miles, do all of these for the sake of safety:- Radiator- Radiator Hoses x2- Small hose to Reservoir- Reservoir- ThermostatGood to know. Tstat and ETC were done last year. Going to do a manual swap soon so I'll have the motor out any way should be a good time to do everything then provided the radiator can hold out for a while. Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 3, 2008 Report Share Posted November 3, 2008 Good to know. Tstat and ETC were done last year. Going to do a manual swap soon so I'll have the motor out any way should be a good time to do everything then provided the radiator can hold out for a while.it should hold out.... just make sure you keep an eye on your coolant level and color Link to comment Share on other sites More sharing options...
lookforjoe Posted November 3, 2008 Report Share Posted November 3, 2008 ..I wouldn't wait... Murphy's law typically works predominantly on those who've been made aware, but chose to ignore the warning... the radiator may well be split higher up in the side tank - look under the upper hose & above the oil cooler line - and running down from there. If you leave it more than a few days, you're asking for serious problems. If the rad blows out on the road, you'll be looking at a much larger bill.You can get the rad online for around 125 - I just did one on my son's XC @ 189KAll OEM Parts, INc (Partsbin) VO3010105 Link to comment Share on other sites More sharing options...
jnderr Posted November 4, 2008 Author Report Share Posted November 4, 2008 ..I wouldn't wait... Murphy's law typically works predominantly on those who've been made aware, but chose to ignore the warning... the radiator may well be split higher up in the side tank - look under the upper hose & above the oil cooler line - and running down from there. If you leave it more than a few days, you're asking for serious problems. If the rad blows out on the road, you'll be looking at a much larger bill.You can get the rad online for around 125 - I just did one on my son's XC @ 189KAll OEM Parts, INc (Partsbin) VO3010105Ordered and done. Thanks Hussein and everyone else. Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 4, 2008 Report Share Posted November 4, 2008 Ordered and done. Thanks Hussein and everyone else.Name is Davit Link to comment Share on other sites More sharing options...
Ghost Shadow Posted November 4, 2008 Report Share Posted November 4, 2008 You can get the rad online for around 125 - I just did one on my son's XC @ 189KAll OEM Parts, INc (Partsbin) VO301010598 and older rad right? 99+ cost more IIRC cost $225 Link to comment Share on other sites More sharing options...
7 VII 7 Posted November 4, 2008 Report Share Posted November 4, 2008 98 and older rad right? 99+ cost more IIRC cost $225I believe that is the case Link to comment Share on other sites More sharing options...
jnderr Posted November 4, 2008 Author Report Share Posted November 4, 2008 Name is DavitOh Thank You Davit Link to comment Share on other sites More sharing options...
FredMc Posted November 17, 2008 Report Share Posted November 17, 2008 I have to replace my radiator this weekend, I didn't get an oem one. Question? any photos on how to do this correctly.I heard you have to bottom drop it out? And I will have new readiator hoses for the install, This is a S70 T5, 152K, runs good. But the drip is just where you guys said on the side of the upper radiator hose above the oil hose. Probably split on the seams of the radiator?Thanks Link to comment Share on other sites More sharing options...
Chilled man Posted November 17, 2008 Report Share Posted November 17, 2008 OEM Rad from jamie $225 shipped yeah and dont wait they do split ----- purple coupe------ :huh: Link to comment Share on other sites More sharing options...
