turbowagoneer855 Posted November 7, 2008 Report Share Posted November 7, 2008 ...and don't have the HAynes with me, forgot it at the shop.so what's the "scientific" name and what does it do? it's located on the intake hose going into the turbo. It's sort of an electric valve??anyways, here's a pic: another Q: the bottom gasket is ready to go into the trash, it's mushy and cracked (i'm sure that's it's still the original in there). Do I need to buy the whole part to be able to get a new seal,? (since I can't name it, I can't search!)Thanks a mill! Link to comment Share on other sites More sharing options...
flyfishing3 Posted November 7, 2008 Report Share Posted November 7, 2008 i'm not a 850 guy but isn't that a tcv. Link to comment Share on other sites More sharing options...
jdlc Posted November 7, 2008 Report Share Posted November 7, 2008 ...and don't have the HAynes with me, forgot it at the shop.so what's the "scientific" name and what does it do? it's located on the intake hose going into the turbo. It's sort of an electric valve??anyways, here's a pic: another Q: the bottom gasket is ready to go into the trash, it's mushy and cracked (i'm sure that's it's still the original in there). Do I need to buy the whole part to be able to get a new seal,? (since I can't name it, I can't search!)Thanks a mill!It's called PTC nipple. It's a nipple.... what can I say, lol. You can't buy that part by itself, you have to get the intake hose where it's installed. http://www.fcpgroton.com/product-exec/prod.../category_id/65 Link to comment Share on other sites More sharing options...
mkc70 Posted November 7, 2008 Report Share Posted November 7, 2008 You can see the sensor on the "turbo air intake hose" from vendor images online. I took mine off as well and have been unable to find it individually from the hose. Thought it was part of the pcv system. Googled the part# and came up with nada. Link to comment Share on other sites More sharing options...
turbowagoneer855 Posted November 7, 2008 Author Report Share Posted November 7, 2008 I've double-checked in chilton's, and the pic on page 4-27 shows a certain "pressure servo wastegate valve", and a "tc control valve" (turbo only, it says)sooooo, it might be R then ?? the arrow on the illustration kinda points in the general area where it's actually located... Link to comment Share on other sites More sharing options...
turbowagoneer855 Posted November 7, 2008 Author Report Share Posted November 7, 2008 I've double-checked in chilton's, and the pic on page 4-27 shows a certain "pressure servo wastegate valve", and a "tc control valve" (turbo only, it says)sooooo, it might be R then ?? the arrow on the illustration kinda points in the general area where it's actually located...hehe, I quote myself: (don't have correction rights yet! )the thing is marked R in the book... Link to comment Share on other sites More sharing options...
sconeman Posted November 7, 2008 Report Share Posted November 7, 2008 I've double-checked in chilton's, and the pic on page 4-27 shows a certain "pressure servo wastegate valve", and a "tc control valve" (turbo only, it says)sooooo, it might be R then ?? the arrow on the illustration kinda points in the general area where it's actually located...No, the PTC is normally sold installed already in the intake tube and is found just prior to the compressor (turbo) inlet. the compress intake tube is the 2.5 inch black plastic tube that goes from the air filter box to the turbo inlet. Link to comment Share on other sites More sharing options...
turbowagoneer855 Posted November 7, 2008 Author Report Share Posted November 7, 2008 google to the rescue:PTC nippleI googled "PTC nipple" easy when one knows the "right' term.... Link to comment Share on other sites More sharing options...
Oreo931 Posted November 7, 2008 Report Share Posted November 7, 2008 Same thing happened to me. I had to buy a whole new hose from the dealer. Link to comment Share on other sites More sharing options...
randomdude Posted November 7, 2008 Report Share Posted November 7, 2008 maybe put some silicone or something around the seal before you put in and then some more on the outside to seal it off to get you by for a while. what does this part due? it looks like a pcv check ball valve inside, so i sprayed mine out with metal parts cleaner, was that ok? Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted November 7, 2008 Report Share Posted November 7, 2008 You could probably get a used one off a junked car. I clean mine out every oil change, as oil and crap gets in there Link to comment Share on other sites More sharing options...
randomdude Posted November 7, 2008 Report Share Posted November 7, 2008 could a poor seal around the base be causing a intermitten vac leak? Link to comment Share on other sites More sharing options...
turbowagoneer855 Posted November 7, 2008 Author Report Share Posted November 7, 2008 thanks everyone for helping so quickly!i guess the 2nd question still stands: can I just find a replacement for the rubber grommet??meanwhile, found another interesting reading on same subject: the nipple!more PTC stuff Link to comment Share on other sites More sharing options...
randomdude Posted November 7, 2008 Report Share Posted November 7, 2008 no replacement seal as far as i know. perhaps try my recommendation of dumping silicone in and around the seal. Link to comment Share on other sites More sharing options...
Oreo931 Posted November 7, 2008 Report Share Posted November 7, 2008 thanks everyone for helping so quickly!i guess the 2nd question still stands: can I just find a replacement for the rubber grommet??meanwhile, found another interesting reading on same subject: the nipple!more PTC stuffNo...Like I said, you need a new hose. The part is called a "fresh air hose" Link to comment Share on other sites More sharing options...
