mbsl98 Posted November 10, 2008 Report Share Posted November 10, 2008 We just had a couple of instances where the throttle on an 850NA stuck wide open after being floored. No jokes about NA and being floored....... Anyway, it turned out to be simply a lube issue, on the shaft that the throttle cable spool rotates on. I mention it because I have never pulled that spool to clean and lube its shaft on any of our Volvo's, and that could have ended up in a good accident. I only slid the spool about half-way off the shaft because I didn't know if the big spring in there would come loose That was enough to work some PB Blaster in, and follow it with a few squirts of oil. The spool is only held with a C-clip. Anyone know what happens if you just slide the spool right off the shaft? I've got a few more of these to get to, now that I see the potential. Note that this spool is the same on all 850/X70's, turbo or not, AFAIK. Link to comment Share on other sites More sharing options...
TNOMUD Posted November 10, 2008 Report Share Posted November 10, 2008 not enough lube on the shaft is the worst.......... :huh: Link to comment Share on other sites More sharing options...
Ronny Posted November 11, 2008 Report Share Posted November 11, 2008 ba dum bum.......... Link to comment Share on other sites More sharing options...
mbsl98 Posted November 11, 2008 Author Report Share Posted November 11, 2008 At least they are not NA jokes Link to comment Share on other sites More sharing options...
