turbormonkey Posted November 14, 2008 Report Share Posted November 14, 2008 Hi guys my mechanic worked on my car fixing the dash noise and he does not know where this grounding strap goes on my 98 s70 Here is a pic below, also he thinks he remembers it having a different bolt than the rest. he looked on vadis and could not find this wire mentioned. Anybody who can help I would much appreciate If you can take a pic of yours and the bolt that goes through it, i would really appreciate. here is a pic of the bolt he found in picture 2, is this correct and is their suppose to be another nut on this bolt or is this all, also where does it attach. Link to comment Share on other sites More sharing options...
crazykn Posted November 14, 2008 Report Share Posted November 14, 2008 That grounding strap might be for the airbag. Plus from where you take that photo there isn't normally any equipment ground (those are found near the driver side). I know many years ago there was a recall to get a grounding strap installed onto the airbag case, because there was a possibility of static building up (with no where to ground) and discharging the airbag. Link to comment Share on other sites More sharing options...
turbormonkey Posted November 14, 2008 Author Report Share Posted November 14, 2008 That grounding strap might be for the airbag. Plus from where you take that photo there isn't normally any equipment ground (those are found near the driver side). I know many years ago there was a recall to get a grounding strap installed onto the airbag case, because there was a possibility of static building up (with no where to ground) and discharging the airbag.OK it is the airbag grounding strap after research but it says it has to be inserted into a specific hole on the bottom of the airbag, their are three holes that attach the airbag dash cap to the lower dash which hole does it go into. If someone could check real quick i would appreciate it takes two seconds to take out the glovebox liner on the 70's Link to comment Share on other sites More sharing options...
