bmx9854 Posted November 25, 2008 Report Share Posted November 25, 2008 I am intent on purchasing some kind of recaro, probably recaro, type seat for my 850. I would like to see some pics of brackets either made or that can be bought. I know there is a lot of confusion with s70 seat brackets for 1998 and I was wondering if anyone has actually tested and found whether or not they are the same. If they are the same as the 850, I believe Recaro offers a mount which would be quite convenient. Link to comment Share on other sites More sharing options...
--Aaron-- Posted November 25, 2008 Report Share Posted November 25, 2008 oh noes volvos belong w/ heated leather seats on a real note though good luck with the project Link to comment Share on other sites More sharing options...
bmx9854 Posted November 25, 2008 Author Report Share Posted November 25, 2008 oh noes volvos belong w/ heated leather seats on a real note though good luck with the projectI don't need heated seats if I only drive it in the summer!! Link to comment Share on other sites More sharing options...
--Aaron-- Posted November 25, 2008 Report Share Posted November 25, 2008 I don't need heated seats if I only drive it in the summer!!true good luck to ya Link to comment Share on other sites More sharing options...
Jaxx Posted November 25, 2008 Report Share Posted November 25, 2008 planning on installing a harness? Don't strap it to the floor. Link to comment Share on other sites More sharing options...
gdizzle Posted November 25, 2008 Report Share Posted November 25, 2008 Fabricating is a huge pain.Talk to Carson about rails, brackets, and seats. Link to comment Share on other sites More sharing options...
bmx9854 Posted November 25, 2008 Author Report Share Posted November 25, 2008 No ideas on the compatiblity between S70 and 850 brackets? Link to comment Share on other sites More sharing options...
TorqueSteer Posted November 25, 2008 Report Share Posted November 25, 2008 No ideas on the compatiblity between S70 and 850 brackets?Im pretty sure they are different for the 99's and up, 98 may be the same, but I did my seats 2 years ago and cant remember. I used steel beams and grade 8 bolts to make my own brackets. Link to comment Share on other sites More sharing options...
randomdude Posted November 26, 2008 Report Share Posted November 26, 2008 i was gonna make a thread about this since the search engine brought nothing. thanks for saving me the time, lol. it seems you have to make your own brackets from what ive gathered. it would be so sweet to get them mounted to the electric bracketry. but maybe you could make the seats a bit lower if you made your own. JAXX- why not mount to the floor? Link to comment Share on other sites More sharing options...
gdizzle Posted November 26, 2008 Report Share Posted November 26, 2008 Im pretty sure they are different for the 99's and up, 98 may be the same, but I did my seats 2 years ago and cant remember. I used steel beams and grade 8 bolts to make my own brackets.negative. 98, 99, 00 are the same. Link to comment Share on other sites More sharing options...
Jaxx Posted November 26, 2008 Report Share Posted November 26, 2008 JAXX- why not mount to the floor?It's cool if you don't like walking. has to do with spinal compression when you're in an accident. instead of restraining you, it pushes you down from what I understand.basically, it will break your back in any decent accident. Link to comment Share on other sites More sharing options...
gdizzle Posted November 26, 2008 Report Share Posted November 26, 2008 It's cool if you don't like walking. has to do with spinal compression when you're in an accident. instead of restraining you, it pushes you down from what I understand.basically, it will break your back in any decent accident.Actually, it has more to do with the angle of the straps off the back of the seat and less to do with mounting to the floor. Link to comment Share on other sites More sharing options...
randomdude Posted November 26, 2008 Report Share Posted November 26, 2008 ^so do you want the mounting points closer or farther away from the seats? Link to comment Share on other sites More sharing options...
TorqueSteer Posted November 26, 2008 Report Share Posted November 26, 2008 it would be so sweet to get them mounted to the electric bracketry.Thats exactly what I did. Link to comment Share on other sites More sharing options...
TorqueSteer Posted November 26, 2008 Report Share Posted November 26, 2008 ^so do you want the mounting points closer or farther away from the seats?The professional setups with a full roll cage will have a harness bar which is right behind the seat. The belt then straps to the harness bar. Im using the rear passenger (on the drivers side) seat belt mounting point for my harness. I showed the setup to an insurance accident / safety investigator who also partakes in SCCA racing, and he said it was ok. Link to comment Share on other sites More sharing options...
