harleyhv Posted December 7, 2008 Report Share Posted December 7, 2008 OkHere is the situation. Last august: installed Eibach / Koni FSD, changed everything (spring seats, top plates, bolts, bumpers, name it... all oem) & got the car alignedInstalled winter tires on my metis wheels at the end of october.Last week, while I had the exhaust installed, I asked for a tire rotation.(rear wheels with 1deg positive camber necessitating frequent rotation until I install IPD's rear camber kit)so far so good.Beginning of the week, noticed major ( and I mean car shaking major) vibrations in "heavy load acceleratiion"I thought it could be a un-balanced wheel.... so I had it checked yesterday. All wheels are fine, no adjustment needed...Just in case, rotate the wheels again.... Vibration under load is still there but not as drastic as before the last rotation..and there is no vaibration whatsoever while cruising (no load).What could this be?Steering rack play?Transmission arm issue? Any help would help.thanks Link to comment Share on other sites More sharing options...
Joey P. Posted December 7, 2008 Report Share Posted December 7, 2008 I''m going to say you have a bad front cv joint in the axle half shaft. Link to comment Share on other sites More sharing options...
DonutsDemise Posted December 7, 2008 Report Share Posted December 7, 2008 are you losing power when it vibrates? or is it like when you floor it in 5th gear going 30mph making it feel like a diesel truck? I would check your engine mounts/torque rods and bushings Link to comment Share on other sites More sharing options...
harleyhv Posted December 7, 2008 Author Report Share Posted December 7, 2008 are you losing power when it vibrates? or is it like when you floor it in 5th gear going 30mph making it feel like a diesel truck? I would check your engine mounts/torque rods and bushingsNo loss of power when accelerating.. vibration present under load. Can even feel it (not as much) on the cruise control when it accelerates to keep up selected speed. Link to comment Share on other sites More sharing options...
sconeman Posted December 7, 2008 Report Share Posted December 7, 2008 No loss of power when accelerating.. vibration present under load. Can even feel it (not as much) on the cruise control when it accelerates to keep up selected speed.could be an axle/ bad cv joint Link to comment Share on other sites More sharing options...
T5gruppy Posted December 7, 2008 Report Share Posted December 7, 2008 Definitely a bad axle. Link to comment Share on other sites More sharing options...
harleyhv Posted December 7, 2008 Author Report Share Posted December 7, 2008 Definitely a bad axle.Ok.,,, bad axle possible cause no 1.We notice also some play in the steering rack ... However, as far as I'm concern, this play was always there... could this be another cause? Link to comment Share on other sites More sharing options...
harleyhv Posted December 14, 2008 Author Report Share Posted December 14, 2008 Did a search for a drive axle assemblyIPD: DSS: 175$ / side. it seems like the best optionhttp://www.ipdusa.com/Volvo-V70XC70-2001-2...p-127-389-3900/OEM: a little expansive.....myswedishparts.com left: 404{:content:}nbsp; right: 464$http://www.trademotion.com/partlocator/ind...playCatalogid=0Vlvoworld: about the same prices as myswedishparts.comhttp://www.vlvworld.com/indexframe.html?V70_01/toc.htmOthers:FCP, Eeuroparts do not carry these axlesNot sure if I can trust what I can find on ebay... seems too good to be true.Rigth assembly: 135$http://cgi.ebay.ca/VOLVO-S60-V70-S60-2-5T-...p3286.m20.l1116left assembly: 80$http://cgi.ebay.ca/VOLVO-S60-A-T-FWD-TURBO...p3286.m20.l1116Any other good and reputable source for the axles? Link to comment Share on other sites More sharing options...
DonutsDemise Posted December 14, 2008 Report Share Posted December 14, 2008 ipd axles are solid. check out raxles for a less expensive alternative Link to comment Share on other sites More sharing options...
Joey P. Posted December 14, 2008 Report Share Posted December 14, 2008 I went with europartsdirect.com and purchased both front axles from them and they were reman type done by OP parts. I don't know who they are but I installed the axles and I've put 15,000 miles on them with no problems. The axles did seem to be of good quality, just not original Volvo parts. I usually stay away from reman non OEM parts like scan tech, and what not, but I just couldn't spend $600-$800 for axles at the time I did it. Best part is that I paid $200 for both from europartsdirect.com. So, the choice is yours, I went cheap on parts that may be reman and probably built in China, but I've had 0 problems. One of those little gambles, I guess. Link to comment Share on other sites More sharing options...
harleyhv Posted December 24, 2008 Author Report Share Posted December 24, 2008 UpdateI was able to reach Raxles.comEssentially, if you have a 1999+volvo, you are SOL with raxles.Reason being (if I understood correctly): * Raxles has the core * outer cv joint in the after market is only made in China and Raxles won't touch it. Seems to me that IPD is the only way to go other than OEM at the stealership.Other question:Do I need to replace the Drive Axle Seals when replacing the axle?http://www.fcpgroton.com/product-exec/prod...category_id/103 Link to comment Share on other sites More sharing options...
MrWinkey Posted December 26, 2008 Report Share Posted December 26, 2008 Other question:Do I need to replace the Drive Axle Seals when replacing the axle?http://www.fcpgroton.com/product-exec/prod...category_id/103You don't have to but it won't hurt...Your call just more work Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted December 26, 2008 Report Share Posted December 26, 2008 UpdateI was able to reach Raxles.comEssentially, if you have a 1999+volvo, you are SOL with raxles.Reason being (if I understood correctly): * Raxles has the core * outer cv joint in the after market is only made in China and Raxles won't touch it. Seems to me that IPD is the only way to go other than OEM at the stealership.Other question:Do I need to replace the Drive Axle Seals when replacing the axle?http://www.fcpgroton.com/product-exec/prod...category_id/103Did you check with Jamie and Don at Waltrip for the OEM price? Link to comment Share on other sites More sharing options...
harleyhv Posted December 28, 2008 Author Report Share Posted December 28, 2008 Did you check with Jamie and Don at Waltrip for the OEM price?Mr.Winkey => Thanks for the infoWaltrip = http://www.darrellwaltripvolvo.com/ I guess...? I sent them an email. expecting the same price as "All my swedish parts.com"IPD and Quickparts are "out of stocK" for the right side axle (DSS 7818N). Awaiting feedback from them.I may have to go to europartsdirect.com or BMA auto parts with the OParts axles. Joey P. seems to have a good experience with these.In the meantime, car is vibrating like no tomorrow.... fun, fun, fun..... Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted December 28, 2008 Report Share Posted December 28, 2008 Mr.Winkey => Thanks for the infoWaltrip = http://www.darrellwaltripvolvo.com/ I guess...? I sent them an email. expecting the same price as "All my swedish parts.com"IPD and Quickparts are "out of stocK" for the right side axle (DSS 7818N). Awaiting feedback from them.I may have to go to europartsdirect.com or BMA auto parts with the OParts axles. Joey P. seems to have a good experience with these.In the meantime, car is vibrating like no tomorrow.... fun, fun, fun.....call Don for the VS deal at 800-679-6124 Link to comment Share on other sites More sharing options...
