Big Boom From The Trunk
Guest 850t514psi
Guest 850t514psi
I have a 95' 850 sedan and I have a 10" W7 that I took out of my last car. I want a custom box for it, but I'm torn, I have had some tell me to have the sub shooting up towards the rear 6x9's, and I have had others tell me to have it shoot towards the rear seats. I have the factory bandpass box from JL, but not sure if I want to stick with it. Money isn't really an issue its just the planning that is killing me. As far as the rest of the system I'm going to have components in the kicks in front, and I have 6x9's in the rear already. So if anyone has some pointers to give that would rock. Thanks guys!!!! :D
95 850 t5
14 psi :blink:
HKS turbo timer
MBC
2.5" Turbo back, catless
magnaflow pipe
Soon to come: :o
18"R rims
Big brake upgrade
chip
Bilsteins
  • Replies 33
95 850 t5
14 psi :blink:
HKS turbo timer
MBC
magnaflow pipe
Soon to come: :o
18"R rims
Big brake upgrade
chip
Bilsteins
Do you really think that where the 10" is pointed will make that big of deal? Dam it's a W7!...And it's in a bandpass box... dude, you're neighbors will hear you 10 blocks away! ... My JL sub points straight up, and It's big bad loud.. Mine is a 12" W0.
It's not totally different. A bandpass box (actually 2 'boxes' or chambers) allows the sub to only play a certain range of frequencies. Hence it only passes a small section, or band, of the music frequencies. This is accomplished by varying the size and type of chambers. i.e. sealed rear box firing into a ported front box. Or a ported rear box firing into a sealed front box or ported rear firing into a ported front. Each of these designs has their own 'Order'. that's why you'll hear things referred to as a "5th order bandpass box" or a 4th order, etc.
The problem with bandpass boxes is that if they aren't designed just right for the woofer you are using then you can/will cause MAJOR damage to the woofer. The worst part is, because of the bandpass design, you won't hear your woofer self-destructing. :blink:
-Chris
This is what I have in my trunk. Custom made box for a JL 10" W3 I believe. Dual Voice Coil.
They built the box large enough so that a 12" will fit if the 10" was not enough. For my tastes, it is plenty.
It is a Sealed box with Fiberglass resin coating the inside to fully ensure no air leaks.
Guest 850t514psi
me either... no need.
I never really thought about the pressure from the sub acutally will screw with the rear deck speakers. With that in mind I might just get some components and put them in the rear doors, along with a sh!t load of Dynamat to prevent rattling embarassment. So with removing the rear 6x9's I'll get matching material to cover those holes, to provide breathing room for the W7. So you guys think that I should just stick with the factory box and just save some sheckles?? Because I could always use some extra money for the 16T that I am going to put in very soon too... But back to the W7 I am going to have a quick disconnect for the sub incase I want less weight in the rear because that sh!t is heavy!!!...
Thanks for all your replies guys. Drive it like you stole it!! B)
