FistFull Posted December 11, 2008 Report Share Posted December 11, 2008 My friend and I installed a digital Prosport boost gauge in my S60 T5 and everything has been great but lately its been reading 15+psi when my foot isn't even on the gas.....is the tubing going bad or is my turbo about to die/ blow up/ etc....has this happen to you? Please share.. Link to comment Share on other sites More sharing options...
Jaxx Posted December 11, 2008 Report Share Posted December 11, 2008 electronic? make sure that the grounds are good first of all. Link to comment Share on other sites More sharing options...
johnloves850's Posted December 11, 2008 Report Share Posted December 11, 2008 i've heard of the digital boost gauges showing vacuum at start up, and it was confused for boostbut if thats not the case, deff go with the post above mecheck the grounds and make sure the piping is connected to the correct placefor example, connecting it to the boost sensor line, instead of a tube coming off of the intake manifold like it tells you to do on the box of some boost gauges Link to comment Share on other sites More sharing options...
--Aaron-- Posted December 11, 2008 Report Share Posted December 11, 2008 +1 on checking the grounds. If you grounded to a painted surface be sure to sand, scrape (whatever works) the paint so it's a nice metal to metal connection. Link to comment Share on other sites More sharing options...
FistFull Posted December 13, 2008 Author Report Share Posted December 13, 2008 i've heard of the digital boost gauges showing vacuum at start up, and it was confused for boostbut if thats not the case, deff go with the post above mecheck the grounds and make sure the piping is connected to the correct placefor example, connecting it to the boost sensor line, instead of a tube coming off of the intake manifold like it tells you to do on the box of some boost gaugesit is connected to the intake man. looks like i have to get some new lines and redo it? Link to comment Share on other sites More sharing options...
CO.T5M Posted December 26, 2008 Report Share Posted December 26, 2008 its ok to go to the vac tree thats the best spot and on your car there is not line cause you have no guage in the cabin Link to comment Share on other sites More sharing options...
