R wagon Posted December 13, 2008 Report Share Posted December 13, 2008 i believe its from the engine, but at idle, my engine starting ticking pretty loud. but once i drove it it went away. what would cause this and should i be worried?Ben Link to comment Share on other sites More sharing options...
9883 Posted December 13, 2008 Report Share Posted December 13, 2008 i believe its from the engine, but at idle, my engine starting ticking pretty loud. but once i drove it it went away. what would cause this and should i be worried?Beninjectors? Link to comment Share on other sites More sharing options...
Keaton85 Posted December 13, 2008 Report Share Posted December 13, 2008 http://volvospeed.com/vs_forum/index.php?s...ode=adv&f=0Go to the subtopic area "fwd/AWD 1998 and prior" click search titles only and then type in noise or ticking or lifters.injectors?no Link to comment Share on other sites More sharing options...
Boost_Junky Posted December 13, 2008 Report Share Posted December 13, 2008 good time to mention it. get a mechanics stethiscopecould be the purge valve, mine ticks loudcould be injectorscould be lifterscould be any rotating piece of metal on metal Link to comment Share on other sites More sharing options...
magicaljake Posted December 13, 2008 Report Share Posted December 13, 2008 make sure you have enough oil Link to comment Share on other sites More sharing options...
R wagon Posted December 13, 2008 Author Report Share Posted December 13, 2008 injectors?so injectors going bad or what? Link to comment Share on other sites More sharing options...
T5gruppy Posted December 13, 2008 Report Share Posted December 13, 2008 Definitely sounds like your lifters, once they get some oil pressure they quiet down... After you shut the car off they have whats called lifter bleed down, in some cases the engine wont even start its so bad. Link to comment Share on other sites More sharing options...
erikv11 Posted December 13, 2008 Report Share Posted December 13, 2008 not too serious but oil pan o-ringsdo the search Link to comment Share on other sites More sharing options...
Keaton85 Posted December 13, 2008 Report Share Posted December 13, 2008 Ok here it is...1: Make sure your filter has a check valve2: If the filter is good change out your o-rings3: If the noise is still their then try a treatment of Auto-RX Link to comment Share on other sites More sharing options...
Azn Renegade Posted December 13, 2008 Report Share Posted December 13, 2008 make sure you have enough oilyea definitley check...mine ticks real bad when im running low on oili somehow have oil residue around the engine oil cap and im PRETTY sure its under the engine coverstill got to figure out where its coming from :( Link to comment Share on other sites More sharing options...
Keaton85 Posted December 13, 2008 Report Share Posted December 13, 2008 yea definitley check...mine ticks real bad when im running low on oili somehow have oil residue around the engine oil cap and im PRETTY sure its under the engine coverstill got to figure out where its coming from gasket or PCV or quicklube has bad aim Link to comment Share on other sites More sharing options...
TEN8US D Posted December 14, 2008 Report Share Posted December 14, 2008 I'll add "loose exhaust manifold." on my S40, I had some manifold nuts vibrate loose, and even lost a stud. When cold, the engine would tick so loudly that I was sure there was something major wrong with it. It sounded like there was a midget in my engine compartment banging on the block with a 5lb sledge. Then I found the loose nuts, tightened them and replaced the stud. No more ticking. I was lucky; on my old Pathfinder, the studs broke at the block and were a pain to extract. Link to comment Share on other sites More sharing options...
volvoskiah Posted December 15, 2008 Report Share Posted December 15, 2008 Add a little oil. I do that when i hear ticking and 99% of the time it goes away. Link to comment Share on other sites More sharing options...
1999_V70 Posted December 15, 2008 Report Share Posted December 15, 2008 Add a little oil. I do that when i hear ticking and 99% of the time it goes away.That's not normal. Link to comment Share on other sites More sharing options...
volvoskiah Posted December 15, 2008 Report Share Posted December 15, 2008 It works lol Link to comment Share on other sites More sharing options...
