Guest new orleans Posted December 15, 2008 Report Share Posted December 15, 2008 hello,i am having a message on the dash saying that coolant level is low stop the engine ASAP.. I checked the coolant level but it is ok... what do you thin is the problem? any idea what i should do? it disappears and comes back later...thanks in advance.. Link to comment Share on other sites More sharing options...
vegasjetskier Posted December 15, 2008 Report Share Posted December 15, 2008 Could be a bad level sensor in the bottom of the coolant tank. Link to comment Share on other sites More sharing options...
neworleans Posted December 15, 2008 Report Share Posted December 15, 2008 is it easier to change it?? can i do it by myself? Link to comment Share on other sites More sharing options...
bes4420 Posted December 17, 2008 Report Share Posted December 17, 2008 I changed one...very easy. I didn't even take the fluid out of the resevoir. It took about 5 minutes. Link to comment Share on other sites More sharing options...
neworleans Posted December 17, 2008 Report Share Posted December 17, 2008 can you tell me little bit about what i need to do? what part do I need to buy and where should I get it from, how much is it and some instructions to change it... thanks in advance... and by the way, did you have the same message on your message screen??? is that why you changed it??? Link to comment Share on other sites More sharing options...
Guest checksix Posted December 17, 2008 Report Share Posted December 17, 2008 can you tell me little bit about what i need to do? what part do I need to buy and where should I get it from, how much is it and some instructions to change it... thanks in advance... and by the way, did you have the same message on your message screen??? is that why you changed it??? Link to comment Share on other sites More sharing options...
Guest CHECKSIX Posted December 17, 2008 Report Share Posted December 17, 2008 Sorry about the previous messed up post Before you change out the sensor consider this: When the car is cold the fluid contracts and it leaves the level sensor low enough to trigger the warning. You mentioned this goes off later. Well as the fluid warms up it expands just enough to trip off the sensor. From my "arm chair" perspective, it just sounds like you are an ounce or 2 low on coolant. Next time the system is cold, add fluid up to a little beyond the min line and report back to us what happens. BTW I know as this is exactly what happened to me, Ha Ha!!!Good Luck! Jerry01 V70 T5a Link to comment Share on other sites More sharing options...
neworleans Posted December 18, 2008 Report Share Posted December 18, 2008 thank you very much for your time and help.. I will do what you say. I bought some coolant fluid from wallmart that says for all cars, and when I opened the hood to add some, it says only volvo coolant... would that be a problem if I add from this fluid??? thanks again.. Link to comment Share on other sites More sharing options...
JesterKB Posted December 19, 2008 Report Share Posted December 19, 2008 thank you very much for your time and help.. I will do what you say. I bought some coolant fluid from wallmart that says for all cars, and when I opened the hood to add some, it says only volvo coolant... would that be a problem if I add from this fluid??? thanks again..At this point ya have a choice. If you only plan to add a few ounces and you don't live where it gets really cold, just add water. If you add the Wal-Mart special, It won't be enough to make much difference. I've read a lot of posts on antifreeze, and my conclusion was to run the Volvo stuff when I did a flush of my system. If you just flushed and everything is new, then get the stuff they put in when it was flushed. If not see the above 2 choices. There are some incompatibilities between brands of antifreeze so use some caution. I too have seen some antifreeze advertise they are compatible with all type and colors, but to tell the truth I've not quite believed it, but that's just me!Jerry01 V70 T5a Link to comment Share on other sites More sharing options...
neworleans Posted December 19, 2008 Report Share Posted December 19, 2008 i will just add some water thank you very much again... Link to comment Share on other sites More sharing options...
BillAileo Posted December 19, 2008 Report Share Posted December 19, 2008 If you don't have Volvo antifreeze on hand, Zerex G-05 antifreeze is about as close to it as your likely to find locally. Link to comment Share on other sites More sharing options...
neworleans Posted January 10, 2009 Report Share Posted January 10, 2009 i think I have got a bad sensor, can you help me out about this issue? what part do I need to order and how I should replace it?? thanks in advance...my car is 2000 s80 T6. Link to comment Share on other sites More sharing options...
T5Chris Posted January 10, 2009 Report Share Posted January 10, 2009 I agree. Bad sensor. Try fcpgroton.com. Not too hard to find, I bought mine on ebay. If you're going to top off with water, use distilled only. Link to comment Share on other sites More sharing options...
neworleans Posted January 10, 2009 Report Share Posted January 10, 2009 is this the part i need to replace?http://www.partsgeek.com/ntparts/sb/oes_ge...33-1661302.htmlif so, is the sensor in this tank? Link to comment Share on other sites More sharing options...
neworleans Posted January 10, 2009 Report Share Posted January 10, 2009 i also found this but can't really relate it to the tank. http://www.statracing.com/oem-replacement/...nt+Level+Sensor Link to comment Share on other sites More sharing options...
