droot Posted December 15, 2008 Report Share Posted December 15, 2008 This one is crazy. my passenger side turn signal will not turn off. I have pull all the fuses and nothing. I am out of idea's on how to diagnose the problem. Thank you for your help.droot Link to comment Share on other sites More sharing options...
Oreo931 Posted December 15, 2008 Report Share Posted December 15, 2008 Check the wiring. I had a similar problem when a few of the turn signal wires were touching each other. I see that you installed sidemarkers so that is a possibility. Link to comment Share on other sites More sharing options...
droot Posted December 15, 2008 Author Report Share Posted December 15, 2008 So I checked the wiring and everything looks great nothing is touching or exposed. Also my right turn signal on the dash board is on and I can make it flash or the emergency lights wont flash either. Could it be a relay?Check the wiring. I had a similar problem when a few of the turn signal wires were touching each other. I see that you installed sidemarkers so that is a possibility. Link to comment Share on other sites More sharing options...
droot Posted December 15, 2008 Author Report Share Posted December 15, 2008 Obviiously "my english no good" The right turn signal on the dash is on and I CAN'T make it flash any thoughts?So I checked the wiring and everything looks great nothing is touching or exposed. Also my right turn signal on the dash board is on and I can make it flash or the emergency lights wont flash either. Could it be a relay? Link to comment Share on other sites More sharing options...
(n)A-GAME Posted December 15, 2008 Report Share Posted December 15, 2008 sounds like a bad hazard switch to me. the hazard switch on your center stack also controls the turn signals....I'd check that first Link to comment Share on other sites More sharing options...
