Guest 99 s70 Posted October 21, 2004 Report Share Posted October 21, 2004 Hi, My wife drives a 1999 v70 N/A with 90,000 miles that stalls occasionally for no apparent reason (according to her). No local shops have been able to find the cause...and it's happened on one other volvo she's driven.Can someone just list the likely (volvo) causes for this problem?She does have a tendency to let the gas go to empty before refilling.Thanks! Link to comment Share on other sites More sharing options...
prasamin Posted October 21, 2004 Report Share Posted October 21, 2004 have they checked your wife? lol!I don't know what it could be...could you give some instances where it has happened...conditions?...at a stop sign, while braking, etc? Link to comment Share on other sites More sharing options...
theunderlord Posted October 21, 2004 Report Share Posted October 21, 2004 Hi, My wife drives a 1999 v70 N/A with 90,000 miles that stalls occasionally for no apparent reason (according to her). No local shops have been able to find the cause...and it's happened on one other volvo she's driven.Can someone just list the likely (volvo) causes for this problem?She does have a tendency to let the gas go to empty before refilling.Thanks!←stalls while driving?while taking off from a light or stop?more so when car is warm?more so when car is cold?more info please. :D Link to comment Share on other sites More sharing options...
Guest Guest_Chris_* Posted October 21, 2004 Report Share Posted October 21, 2004 Probably an intermittent fault in the air mass meter. Sometimes it happens so fast the computer can't catch it and it won't throw the check engine light. Impossible to know for sure so you have to just put one in and see what happens. Link to comment Share on other sites More sharing options...
theunderlord Posted October 21, 2004 Report Share Posted October 21, 2004 Hi, My wife drives a 1999 v70 N/A with 90,000 miles that stalls occasionally for no apparent reason (according to her). No local shops have been able to find the cause...and it's happened on one other volvo she's driven.Can someone just list the likely (volvo) causes for this problem?She does have a tendency to let the gas go to empty before refilling.Thanks!←any CELs? Link to comment Share on other sites More sharing options...
jo346820 Posted October 21, 2004 Report Share Posted October 21, 2004 no CELS or codes I know of...Has been happening for long time...Wife is car illiterate...but from her descriptions, it happens even while at speed...not just coming to a stop or taking off or idling...it seems to happen at random times.I thought, clogged fuel filter due to long time of letting the fuel get to E before refueling.Or...clogged flame trap...or does the 99 v70 not have one?And then, of course, tune-up (: Thanks Link to comment Share on other sites More sharing options...
theunderlord Posted October 21, 2004 Report Share Posted October 21, 2004 no CELS or codes I know of...Has been happening for long time...Wife is car illiterate...but from her descriptions, it happens even while at speed...not just coming to a stop or taking off or idling...it seems to happen at random times.I thought, clogged fuel filter due to long time of letting the fuel get to E before refueling.Or...clogged flame trap...or does the 99 v70 not have one?And then, of course, tune-up (: Thanks←Hmm..... sounds fishy... I suggest you drive the car for a while... Trying to diagnose problems through second hand (even tho it is yer wife) info is always hard. Link to comment Share on other sites More sharing options...
ToxicLemonade Posted October 21, 2004 Report Share Posted October 21, 2004 my mom's s80 had that same problem, left her stranded in the left lane on I-285 during rush our in Atlanta, very dangerous. her problem was a dirty throttle body. so try cleaning it out. hope that helps some. Link to comment Share on other sites More sharing options...
Kashif Posted October 21, 2004 Report Share Posted October 21, 2004 I had the same problem on my 240 a while back and the cause was a faulty fuel pump relay, you could try checking that.She does have a tendency to let the gas go to empty before refilling.Try not letting the gas go to empty because gas is actually a lubricant for the fuel pump. This could lead to fuel pump failure and stalling randomly sounds like a fuel related problem. Recently my 850 died 50 miles from home all of sudden and the cause was a bad fuel pump, and I too was letting the gas near empty too many times. You could check the pressure of your fuel system using a fuel pressure guage. Link to comment Share on other sites More sharing options...
Bay13 Posted October 21, 2004 Report Share Posted October 21, 2004 Someone mentioned it already, the throttle body on the NAs don't fail as often as the turbos, but they do get dirty, and typically what happens is when slowing down and coming to a stop the rpm will surge and or dip and kill the car, it usually starts right back up. Cleaning the TB on the NA 1999 is easy, just take the hose off the air box and the input to the TB and move it as best you can, and then move the flapper and clean it with a rag soaked with a carb cleaner. Link to comment Share on other sites More sharing options...
WhiteT5 Posted October 22, 2004 Report Share Posted October 22, 2004 http://www.volvoclub.org.uk/850_cutting_out.htm Link to comment Share on other sites More sharing options...
Guest Guest Posted August 2, 2005 Report Share Posted August 2, 2005 :( I have a 2000 S80 Turbo with 70K miles on it. The engine stalls and vehicle loses all power (brakes, steering, etc.). Then starts right back up again. Prior to these incidents the dealership replaced a faulty sparkplug coil and a brake pedal sensor. Oct.13, 2004 - 3:45 pm stalled after coasting up small incline, and approaching a stop sign traveling at a rate of 35 mph drive time elapsed prior to stalling: 10 min. comments: prior to stalling EMISSIONS SYSTEM REQUIRES SERVICE lamp illuminated on the dashboard. Action taken:I took the car to the dealership where it was determined that an O2 sensor was defective. The rear O2 sensor was replaced and the message was cleared. Nov. 4, 2004 - 7:00 pm stalled while making a left turn into a parking space traveling at a rate of 10 mph drive time elapsed prior to stalling: 10 min.comments: no error message illuminated. Nov.22, 2004 - 11:30 pm Stalled on winding street in gated community at Golf Course traveling at a rate of 20 mph drive time elapsed prior to stalling: 25 min. comments:EMISSIONS SYSTEM REQUIRES SERVICE lamp illuminated the following day at 9:30 pm. Action taken: I took the car to the dealership where they replaced the front O2 sensor and cleaned the ETM.Jan. 8, 2005 - 12:15 am on freeway decelerating prior to approaching exittraveling at a rate of 70 mph. drive time elapsed prior to stalling: 5 min.comments: EMISSIONS SYSTEM REQUIRES SERVICE lampilluminated immediately. Action taken: I took the car in to the dealership the following morning. This time they were unable to turn off the emissions lamp and claimed it was simply a glitch, or a “ghost”. I was told by my service advisor that my car was performing at optimal levels. He said, “I can tell you with 100% confidence that there is nothing mechanically wrong with the car. It is running just as it is intended to.” June 28, 2005 – 1:30 am on freeway decelerating prior to approaching exit drive time elapsed prior to stalling: 3.5 hours. traveling at a rate of 80 mph. comments: no error message illuminated.June 28, 2005 - 1:32 am just started engine after coming to a stop in an intersection. started car up again and began to make a u-turn. Link to comment Share on other sites More sharing options...
zimmy77 Posted August 2, 2005 Report Share Posted August 2, 2005 I have a 2000 S80 Turbo with 70K miles on it. The engine stalls and vehicle loses all power (brakes, steering, etc.). Then starts right back up again. Prior to these incidents the dealership replaced a faulty sparkplug coil and a brake pedal sensor. Oct.13, 2004 - 3:45 pm stalled after coasting up small incline, and approaching a stop sign traveling at a rate of 35 mph drive time elapsed prior to stalling: 10 min. comments: prior to stalling EMISSIONS SYSTEM REQUIRES SERVICE lamp illuminated on the dashboard. Action taken:I took the car to the dealership where it was determined that an O2 sensor was defective. The rear O2 sensor was replaced and the message was cleared. Nov. 4, 2004 - 7:00 pm stalled while making a left turn into a parking space traveling at a rate of 10 mph drive time elapsed prior to stalling: 10 min.comments: no error message illuminated. Nov.22, 2004 - 11:30 pm Stalled on winding street in gated community at Golf Course traveling at a rate of 20 mph drive time elapsed prior to stalling: 25 min. comments:EMISSIONS SYSTEM REQUIRES SERVICE lamp illuminated the following day at 9:30 pm. Action taken: I took the car to the dealership where they replaced the front O2 sensor and cleaned the ETM.Jan. 8, 2005 - 12:15 am on freeway decelerating prior to approaching exittraveling at a rate of 70 mph. drive time elapsed prior to stalling: 5 min.comments: EMISSIONS SYSTEM REQUIRES SERVICE lampilluminated immediately. Action taken: I took the car in to the dealership the following morning. This time they were unable to turn off the emissions lamp and claimed it was simply a glitch, or a “ghost”. I was told by my service advisor that my car was performing at optimal levels. He said, “I can tell you with 100% confidence that there is nothing mechanically wrong with the car. It is running just as it is intended to.” June 28, 2005 – 1:30 am on freeway decelerating prior to approaching exit drive time elapsed prior to stalling: 3.5 hours. traveling at a rate of 80 mph. comments: no error message illuminated.June 28, 2005 - 1:32 am just started engine after coming to a stop in an intersection. started car up again and began to make a u-turn.←I think I just saw on the news today that volvo/ford is recalling some 200,000 vehicles do to this issue. Link to comment Share on other sites More sharing options...
Guest Guest_whilst_* Posted August 2, 2005 Report Share Posted August 2, 2005 Hi, My wife drives a 1999 v70 N/A with 90,000 miles that stalls occasionally for no apparent reason (according to her). No local shops have been able to find the cause...and it's happened on one other volvo she's driven.Can someone just list the likely (volvo) causes for this problem?She does have a tendency to let the gas go to empty before refilling.Thanks!←The "problem" was on National news last night.Volvo cars under investigation for stalling!Recall maybe coming up.HTH. Link to comment Share on other sites More sharing options...
Guest Guest Posted August 2, 2005 Report Share Posted August 2, 2005 I think I just saw on the news today that volvo/ford is recalling some 200,000 vehicles do to this issue.←I am one of those complaints filed...no recall has been issued yet. If you are having the same problem, or no someone who does, PLEASE file a report at odi.nhtsa.dot.gov to expedite this process. Thank you Link to comment Share on other sites More sharing options...
