Caaine Posted October 22, 2004 Report Share Posted October 22, 2004 I just purchased an S80 that has the HU-611 audio system. I am wondering if there is enough bass in this setup and if it would be easy to add a box in the rear? I.e. preferably without adding an amp (not likely). Not many S80 owners here so I haven´t found much info on S80 audio. Any information would be good. Just worried that the stock setup won´t provide enough bass. Link to comment Share on other sites More sharing options...
theunderlord Posted October 22, 2004 Report Share Posted October 22, 2004 I just purchased an S80 that has the HU-611 audio system. I am wondering if there is enough bass in this setup and if it would be easy to add a box in the rear? I.e. preferably without adding an amp (not likely). Not many S80 owners here so I haven´t found much info on S80 audio. Any information would be good. Just worried that the stock setup won´t provide enough bass.←Well no, it won't be enough bass. no, it won't be easy adding a box & amp with a stock deck. the Swedespeed audio section may be able to help you, there are a bunch of guy over there with the newer cars. Link to comment Share on other sites More sharing options...
Veneficus Posted October 22, 2004 Report Share Posted October 22, 2004 Yeh, Turbobricks is more 200 / 700 series, we're predominatly 800 series and swedespeed is primarily the newer stuff. And no, I doubt you'll ever run a sub w/o an amp off of the stock hu. Link to comment Share on other sites More sharing options...
theunderlord Posted October 22, 2004 Report Share Posted October 22, 2004 Yeh, Turbobricks is more 200 / 700 series, we're predominatly 800 series and swedespeed is primarily the newer stuff. And no, I doubt you'll ever run a sub w/o an amp off of the stock hu.←Don't forget about VS's very capable S/V/C 70 crowd! :D Link to comment Share on other sites More sharing options...
Caaine Posted October 22, 2004 Author Report Share Posted October 22, 2004 Thanks for the replies,Too bad, as I prefer this website over the others. I didn´t explain myself properly, subs with built in amps are viable too, just not placing a speperate amp etc as I want to have a french zipper under it and a single plug so I can remove it when I need the trunk space. Link to comment Share on other sites More sharing options...
theunderlord Posted October 22, 2004 Report Share Posted October 22, 2004 french zipper ←what what what! ? Link to comment Share on other sites More sharing options...
Caaine Posted October 22, 2004 Author Report Share Posted October 22, 2004 hehe,It´s Velcro! Just didn´t find the correct word when writing the previous post. In Icelandic it´s French Zipper. (direct translation) :D Link to comment Share on other sites More sharing options...
Veneficus Posted October 22, 2004 Report Share Posted October 22, 2004 Don't forget about VS's very capable S/V/C 70 crowd! ←^Oops... yeah. Well, technically the 70 series is a continum of the 800 series.Well what bing has said has come out as this towards combinations. Its much cheaper to get a box and an amp (plus you'll get more power) for when you want to have a removable sub. Just have some of those pill shaped connectors on all of your connections and use your French zipper (hehe) to hold it down. You will spend more but its always better to get what you want the first time and not fool around with mediocre things just to tide you over until you get the exact thing you want. Link to comment Share on other sites More sharing options...
The Reverend Posted October 23, 2004 Report Share Posted October 23, 2004 ^Oops... yeah. Well, technically the 70 series is a continum of the 800 series.Well what bing has said has come out as this towards combinations. Its much cheaper to get a box and an amp (plus you'll get more power) for when you want to have a removable sub. Just have some of those pill shaped connectors on all of your connections and use your French zipper (hehe) to hold it down. You will spend more but its always better to get what you want the first time and not fool around with mediocre things just to tide you over until you get the exact thing you want.←Pill shaped connectors? Do you mean those crimp connectors? Link to comment Share on other sites More sharing options...
theunderlord Posted October 23, 2004 Report Share Posted October 23, 2004 Pill shaped connectors? Do you mean those crimp connectors?←I think he means quick disconnects... the ones I've used are either light pink or light blue in color. Link to comment Share on other sites More sharing options...
Veneficus Posted October 23, 2004 Report Share Posted October 23, 2004 Yeah, they're the quick disconnects. Sorry about the confusion there. Link to comment Share on other sites More sharing options...
