Jippi 855 GLT Posted December 28, 2008 Report Share Posted December 28, 2008 walboro pumps are loud... thats what i have in my 855. no air leaks i assume. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 walboro pumps are loud... thats what i have in my 855. no air leaks i assume. meh , better than $300 right? I checked around the turbo lines.... When you told me about the lines I thought maybe my one line that used to pop off all the time from my ST tune. But everything looks in place. I smell fuel & im not seeing anything leaking. But the car started after fueling & driving about 5miles to the food store. It just cranks , stumbles & dies. tomorrow im hitting harry's for a relay before running back to the car. Hopefully my luck is good its the relay. But really , again like I said I really pushed every last cent I could into the tank. I hope I didnt ruin something too costly. Link to comment Share on other sites More sharing options...
rick in denver Posted December 28, 2008 Report Share Posted December 28, 2008 Always go with the cheapest and easiest solutions first. My thinking and I've had this same issue is "bad gas". Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 Always go with the cheapest and easiest solutions first. My thinking and I've had this same issue is "bad gas". yeah , thats what I'm doing with the relay test first. Lets not hope its bad gas from Wawa. What are they gonna do ? laugh at my face? Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted December 28, 2008 Report Share Posted December 28, 2008 meh , better than $300 right? I checked around the turbo lines.... When you told me about the lines I thought maybe my one line that used to pop off all the time from my ST tune. But everything looks in place. I smell fuel & im not seeing anything leaking. But the car started after fueling & driving about 5miles to the food store. It just cranks , stumbles & dies. tomorrow im hitting harry's for a relay before running back to the car. Hopefully my luck is good its the relay. But really , again like I said I really pushed every last cent I could into the tank. I hope I didnt ruin something too costly.9480152 is the pump assembly. I bought the pump assy, fuel filter, relay, gasket, and shipping for $300 i think from Don. Filter may or may not have actually been included. The thing about the Wlabro is you have to hope the housing doesn't disintegrate when you pull it apart too. Good luck. Try the relay bypass first but i wouldn't be surprised if it's junk fuel myself. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted December 28, 2008 Report Share Posted December 28, 2008 when u go get the Fuel pump relay, grab the fuel injection one too. thats the one above the fan. i replaced both of then when i was tracing a no start/random stall issue a while back.. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 when u go get the Fuel pump relay, grab the fuel injection one too. thats the one above the fan. i replaced both of then when i was tracing a no start/random stall issue a while back.. wheres this one at ? near the radiator , the fan speed relay? is there any numbers or color specific? or am I supposed to still be in the fuse box area? Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted December 28, 2008 Report Share Posted December 28, 2008 wheres this one at ? near the radiator , the fan speed relay? is there any numbers or color specific? or am I supposed to still be in the fuse box area? the fuel injection relay is on the rad shroud near the battery side. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 the fuel injection relay is on the rad shroud near the battery side. thats what I was thinking..... we'll see what happens tomorrow. Thanks for being around when I needed a Vs'r!! I owe you my time when your 850 is stranded. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted December 28, 2008 Report Share Posted December 28, 2008 pump won't change the mpg any unless you have a lead foot. normal driving the injectors will do what they're told to do. the pump has no bearing on that, but if you're lead footed the pump will provide as much as it's demanded without hesitation from the stock injectors. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 just got back from trying the few things you people mentioned. I got the relays from the yard ( fuel pump & the fuel injection relay ) . I replaced both & did the jumper trick with no luck. I think im going to go back and try sucking some of that gas out....maybe go as far as emptying the tank & try some new gas. but if this doesnt work out...... I guess the fuel pump. Do I need to drop the tank or could it be done easier that I have the Wagon? but I did get a quote $425 for the pump & $ 240 for installation. :huh: Link to comment Share on other sites More sharing options...
raven_850 Posted December 28, 2008 Report Share Posted December 28, 2008 Change the fuel filter? It's only a 10 minute job. Way cheaper than $300. It may just be water/junk from your last fill up.When you turn the ignition on you should hear the fuel pump start. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 Change the fuel filter? It's only a 10 minute job. Way cheaper than $300. It may just be water/junk from your last fill up.When you turn the ignition on you should hear the fuel pump start. do i need to drop the tank? or can this be done another way? im guessing the filter is in the tank along with the pump? Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted December 28, 2008 Report Share Posted December 28, 2008 the filter is under the car passenger side rear. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 the filter is under the car passenger side rear. gonna go shake out the filter & drain some fuel out of the tank and see what happens. I'm just hoping that I dont need to replace the pump :( Link to comment Share on other sites More sharing options...
