confused_al Posted December 28, 2008 Report Share Posted December 28, 2008 ... but I did get a quote $425 for the pump & $ 240 for installation. ...If you replace w/ Walbro that would be only $65 (shipped) from http://www.europartsdirect.com/Yes, it is a bit louder especially when it just started. I replaced my 95 n/a's a few days ago. It performs a lot better than the OEM one. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted December 28, 2008 Report Share Posted December 28, 2008 filter is a black canister under the passenger side rear, just in front of the rear wheels. there's also a pressure release valve you can use to get some of that gas out instead of siphoning it. as long as your car is awd there's an access port to the fuel pump underneath the carpet right behind the rear passenger side seat. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 filter is a black canister under the passenger side rear, just in front of the rear wheels. there's also a pressure release valve you can use to get some of that gas out instead of siphoning it. as long as your car is awd there's an access port to the fuel pump underneath the carpet right behind the rear passenger side seat. yes found that while I was there again. but I didnt know about the release valve. But I did siphone about 2 gal. out of the tank. still no luck. I guess it really is the pump? So no I dont got the AWD. So tht means I need to drop the tank huh. I guess I'll look into deciding if im going for walboro or OEM. I do plan on keeping the car for a long time. Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted December 28, 2008 Report Share Posted December 28, 2008 yes found that while I was there again. but I didnt know about the release valve. But I did siphone about 2 gal. out of the tank. still no luck. I guess it really is the pump? So no I dont got the AWD. So tht means I need to drop the tank huh. I guess I'll look into deciding if im going for walboro or OEM. I do plan on keeping the car for a long time.i think he meant as long as it is NOT AWD there is an access panel, yes? Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted December 28, 2008 Report Share Posted December 28, 2008 yes found that while I was there again. but I didnt know about the release valve. But I did siphone about 2 gal. out of the tank. still no luck. I guess it really is the pump? So no I dont got the AWD. So tht means I need to drop the tank huh. I guess I'll look into deciding if im going for walboro or OEM. I do plan on keeping the car for a long time.no the AWD you have to drop the entire rear suspension and tank. FWD has the access port in the back so you're good. Besides if you were AWD walboro is not an option since the fuel tank is a horse shoe shapped design with a master pump and secondary pump that flows from one side of the tank to the other and that requires an OEM unit. not that it matters in your case but just an FYI.Have you listened for the fuel pump to come on at all? have someone climb into the rear and listen right above the access port as you turn the key into pos II. they should be able to hear the pump, if it's dead silent then theres your culprit. if they hear a whirring noise, thats not your problem. did you replace the filter while you took some fuel out? Link to comment Share on other sites More sharing options...
raven_850 Posted December 28, 2008 Report Share Posted December 28, 2008 yes found that while I was there again. but I didnt know about the release valve. But I did siphone about 2 gal. out of the tank. still no luck. I guess it really is the pump? So no I dont got the AWD. So tht means I need to drop the tank huh. I guess I'll look into deciding if im going for walboro or OEM. I do plan on keeping the car for a long time.Did you change the fuel filter? It's only $20. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 ok back from the car for the second time..... Heres what I have come up with. I checked the fuel pressure release valve...there was no fuel squirtin out. I climbed into the rear to access the fuel pump. I took off the fuel lines , and still dont have pressure / fuel squirtin. so I guess the pump is really dead ? no noises came from it either. I still havent tried replacing the filter since I have no fuel being pumped. whats your input? Link to comment Share on other sites More sharing options...
raven_850 Posted December 28, 2008 Report Share Posted December 28, 2008 ok back from the car for the second time..... Heres what I have come up with. I checked the fuel pressure release valve...there was no fuel squirtin out. I climbed into the rear to access the fuel pump. I took off the fuel lines , and still dont have pressure / fuel squirtin. so I guess the pump is really dead ? no noises came from it either. I still havent tried replacing the filter since I have no fuel being pumped. whats your input?Have you checked the fuse? Try to eliminate the obvious stuff. K.I.S.S. principle. Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 28, 2008 Author Report Share Posted December 28, 2008 Have you checked the fuse? Try to eliminate the obvious stuff. K.I.S.S. principle. yup that too....... so my guess fuel should be squirtin out of the pump ? I took off the lines going to the pump and no pressure. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted December 29, 2008 Report Share Posted December 29, 2008 if theres no sound then the pump isn't priming and explains the lack of pressure. if you replaced the pump relay then theres your problem. time for the walboro Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 29, 2008 Author Report Share Posted December 29, 2008 if theres no sound then the pump isn't priming and explains the lack of pressure. if you replaced the pump relay then theres your problem. time for the walboro +1 ...... going to the yard tomorrow and get a used pump for now untill I can get a new one. Hopefully this will get the 855 up in running again to get it home. Link to comment Share on other sites More sharing options...
Chilled man Posted December 29, 2008 Report Share Posted December 29, 2008 1. check fuel pump fuese2. check fuel pump relay - used or new if used get two of them 3. check fuel pump for power after jumpering out the relay 4. remove fuel rail connection drain it out and try to turn the car on again-a. have fuel pressure check for spark-b. if no fuel pressure take direct lines from batterie and jumper to fuel pump wires and see if pump runs5. If fuel pressure is back in the line after you start the car , check for spark .if pump doesnt run wiht direct 12v to it pump is bad replace with walrboro and buy it from joesph if pump works both relays are shot / or fuese is poped and you didnt notice it the frist time. Buy a new relay regardles other wise you will be doing this again soon Also get a new fuel filter regardless it shoudl of been replaced by now and takes less then 10 min to do Link to comment Share on other sites More sharing options...
Bazarvospeed Posted December 29, 2008 Author Report Share Posted December 29, 2008 Got the car running again....wheeeew. anyways thanks to all that helped me out, seriously. I dont know how to thank you people , we got one huge friendly family here. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted December 29, 2008 Report Share Posted December 29, 2008 was it the pump??/ Link to comment Share on other sites More sharing options...
Chilled man Posted December 29, 2008 Report Share Posted December 29, 2008 Got the car running again....wheeeew. anyways thanks to all that helped me out, seriously. I dont know how to thank you people , we got one huge friendly family here. best way to help us is to tell us what was wrong and how you fixed it B) Link to comment Share on other sites More sharing options...
