Mogatu'r Posted January 13, 2009 Report Share Posted January 13, 2009 P1 is hydraulicP2 is solid, well actually 99 up 5cyl.Is this a fact? Where did you get the info? thnx Link to comment Share on other sites More sharing options...
villaconn Posted January 13, 2009 Report Share Posted January 13, 2009 I've got two sets of lifters. Looking at the bottoms of them, one seems to be shallow, one seems to be deep. Is it possible that the shallow ones are just full of oil? Thanks for your help.I just took apart an engine and noticed that some of the lifters were sitting higher than others. I thought it would be int v exh, open valve vs closed valve, however, it was a totally random pattern. Besides the fact that I came to my senses realizing all valves are closed since the cams were off, i came to the conclusion that the ones that are sitting lower on the head are collapsed. The "higher" ones had a little bit of give or movement. This let me know that these were still good. The "lower" or collapsed ones did not give at all. What you have there are several collapsed lifters. In my case, since I lost a rod bearing I am attributing it to debris getting in them. The oil coming out of them was sparkly and shiny. Cheers,Ricky Link to comment Share on other sites More sharing options...
villaconn Posted January 13, 2009 Report Share Posted January 13, 2009 I've got two sets of lifters. Looking at the bottoms of them, one seems to be shallow, one seems to be deep. Is it possible that the shallow ones are just full of oil? Thanks for your help.Also, if you look at your first two pictures, you'll see what appears to be an impact mark on one of them. Coincidentally, that one appears to be collapsed or shorter. This is making hard "slap" contact against the valve. If you look at the other one which appears to have the plunger extended, does not have the same marking. This is due to constant contact with the valve and pushing it down in a controlled manner. I hope this makes sense to you.Cheers,Ricky Link to comment Share on other sites More sharing options...
Hilton Posted January 13, 2009 Author Report Share Posted January 13, 2009 Also, if you look at your first two pictures, you'll see what appears to be an impact mark on one of them. Coincidentally, that one appears to be collapsed or shorter. This is making hard "slap" contact against the valve. If you look at the other one which appears to have the plunger extended, does not have the same marking. This is due to constant contact with the valve and pushing it down in a controlled manner. I hope this makes sense to you.Cheers,RickyI put in the ones that look shallow. Hopefully these are the ones that aren't compressed.Thanks. Link to comment Share on other sites More sharing options...
T5gruppy Posted January 14, 2009 Report Share Posted January 14, 2009 Is this a fact? Where did you get the info? thnxI work at the volvo dealership here in VT, im almost certain this is true tho. Link to comment Share on other sites More sharing options...
villaconn Posted January 14, 2009 Report Share Posted January 14, 2009 I put in the ones that look shallow. Hopefully these are the ones that aren't compressed.Thanks.You want to use the ones that have the center piece or plunger sticking out more. Link to comment Share on other sites More sharing options...
the commissar! Posted January 14, 2009 Report Share Posted January 14, 2009 The top one of the two pictures is the good one yes? Not the one with the shiny center... Link to comment Share on other sites More sharing options...
Mogatu'r Posted January 14, 2009 Report Share Posted January 14, 2009 I work at the volvo dealership here in VT, im almost certain this is true tho.This could be great news for me, could you please re-check? Link to comment Share on other sites More sharing options...
Hilton Posted January 14, 2009 Author Report Share Posted January 14, 2009 These are the ones I dropped in. Should I pull them and stick in the others? Link to comment Share on other sites More sharing options...
villaconn Posted January 14, 2009 Report Share Posted January 14, 2009 These are the ones I dropped in. Should I pull them and stick in the others?That one is collapsed. You want the others. New ones are about 15.00/ea which doesn't sound too bad. But when you do 20 of them it adds up to real money. I would not hesitate to put good used ones in there, just make sure they are not collapsed.Cheers,Ricky Link to comment Share on other sites More sharing options...
Hilton Posted January 15, 2009 Author Report Share Posted January 15, 2009 Thanks, I'll swap to the others. Link to comment Share on other sites More sharing options...
Keaton85 Posted January 15, 2009 Report Share Posted January 15, 2009 Who cares if they are collapsed, they will pump back up! key word here is hydraulic haha Link to comment Share on other sites More sharing options...
