Jack8745 Posted January 13, 2009 Report Share Posted January 13, 2009 got a NA intake and a valve cover from a JY last weekend, with the intention of polishing maybe porting the intake. --- i read the topic on a NA intake on a turbo. ---- i recall someone saying that there are 2 bolt patterns on intakes ? if yes what do i look for?the valve cover i got in order to polish it. Im now thinking its not such a good idea to use a different cover then the one that come on my car, since they wear to original engine and switching it might cause problems. Am i right?do i have to take off the t-belt inorder to install the intake?whats the tool used to install the valve coverEDIT: take off the t-belt in order to install the valve cover Link to comment Share on other sites More sharing options...
bum2kev Posted January 13, 2009 Report Share Posted January 13, 2009 got a NA intake and a valve cover from a JY last weekend, with the intention of polishing maybe porting the intake. --- i read the topic on a NA intake on a turbo. ---- i recall someone saying that there are 2 bolt patterns on intakes ? if yes what do i look for?the valve cover i got in order to polish it. Im now thinking its not such a good idea to use a different cover then the one that come on my car, since they wear to original engine and switching it might cause problems. Am i right?do i have to take off the t-belt inorder to install the intake?whats the tool used to install the valve coverEDIT: take off the t-belt in order to install the valve coverthere is no use for the NA intake, only the a NA throttle body. the valve cover cover has 8 bolts holding it on. no need to remove anything to get it off. Link to comment Share on other sites More sharing options...
Jack8745 Posted January 13, 2009 Author Report Share Posted January 13, 2009 there is no use for the NA intake, only the a NA throttle body. the valve cover cover has 8 bolts holding it on. no need to remove anything to get it off. not the plastic spark plug cover the actual engine valve cover. Link to comment Share on other sites More sharing options...
Oreo931 Posted January 13, 2009 Report Share Posted January 13, 2009 not the plastic spark plug cover the actual engine valve cover.Valve covers/Cam covers are mated to the head. They can not be swapped. So basically you bought a nice piece of scrap metal.As per the intake manifold, the tbelt does not have to be removed. Link to comment Share on other sites More sharing options...
Jack8745 Posted January 13, 2009 Author Report Share Posted January 13, 2009 Valve covers/Cam covers are mated to the head. They can not be swapped. So basically you bought a nice piece of scrap metal.As per the intake manifold, the tbelt does not have to be removed.thanks thats what i thought. i meant to write valve cover not intake Link to comment Share on other sites More sharing options...
bum2kev Posted January 13, 2009 Report Share Posted January 13, 2009 haha ya thats what got me, i figured no one would buy just a valve cover.... but yes its true its mated to the head, i would not recommend swapping it on your head. Link to comment Share on other sites More sharing options...
Jack8745 Posted January 13, 2009 Author Report Share Posted January 13, 2009 haha ya thats what got me, i figured no one would buy just a valve cover.... but yes its true its mated to the head, i would not recommend swapping it on your head.hence the topic subtitle - on the way home i realized how dumb i've been Link to comment Share on other sites More sharing options...
Rsterns Posted January 13, 2009 Report Share Posted January 13, 2009 hence the topic subtitle - on the way home i realized how dumb i've beenI wouldn't say dumb at all, everything is a learning process, and sometimes logic just doesn't play into it. If we all had the answers this forum would be vacant! Link to comment Share on other sites More sharing options...
johnloves850's Posted January 14, 2009 Report Share Posted January 14, 2009 would a complete n/a head work on a turbo block?or is it better to use just the cams? Link to comment Share on other sites More sharing options...
CoRalV70 Posted January 14, 2009 Report Share Posted January 14, 2009 would a complete n/a head work on a turbo block?or is it better to use just the cams?Heads do not fit, use the cams even though there kinda meh. Sacrafice more low-end for a little extra high-end. And im not positive but im pretty sure the LPT's already have the N/A cams? Link to comment Share on other sites More sharing options...
johnloves850's Posted January 14, 2009 Report Share Posted January 14, 2009 well i was meaning in general, is it only better to use the camsbut since the n/a and lpt block is almost the same, for the 850'sidk doesn't hurt to try loli'll do it at harry's u-pull itthat's where i test things out before i do it on my own car hahathere's always an n/a and an lpti've seen a few 95 turbo's and t5's too Link to comment Share on other sites More sharing options...
