Jack8745 Posted January 14, 2009 Report Share Posted January 14, 2009 has anyone converted the master window switch to have a dual auto down feature for front windows?plus i know i have seen many of you with the rear window switches illuminated. i cant find how to do itplease helpthanks Jack Link to comment Share on other sites More sharing options...
Serge Posted January 14, 2009 Report Share Posted January 14, 2009 Has been done by many I believe. Just get another relay and wire it up the same way the driver's side is (except for the passenger side, of course).There is a guide out there somewhere about doing the rear lit switch mod. Link to comment Share on other sites More sharing options...
Jack8745 Posted January 14, 2009 Author Report Share Posted January 14, 2009 Has been done by many I believe. Just get another relay and wire it up the same way the driver's side is (except for the passenger side, of course).There is a guide out there somewhere about doing the rear lit switch mod.need more info please, i searched and searched Link to comment Share on other sites More sharing options...
msestina Posted January 14, 2009 Report Share Posted January 14, 2009 Has been done by many I believe. Just get another relay and wire it up the same way the driver's side is (except for the passenger side, of course).There is a guide out there somewhere about doing the rear lit switch mod.My newer car has both auto up and down front windows. A nice convenience feature I'd like to add to the 850 wiring. Any one done that? Link to comment Share on other sites More sharing options...
Serge Posted January 14, 2009 Report Share Posted January 14, 2009 My newer car has both auto up and down front windows. A nice convenience feature I'd like to add to the 850 wiring. Any one done that?Auto up and down on newer cars is done with two things which we don't readily have: hall-effect sensors in (or rather, near) the motors and limit switches (I believe).The auto-down module on 850s and S70s is an interesting device in that it senses a spike in current to detect motor stall. You can test this by putting the window in auto down mode and then grabbing it with both hands to keep it from going down. It should stall out and the relay will click off, thinking it reached the bottom.You can use a second module for the passenger side though (as well as both rears). Link to comment Share on other sites More sharing options...
Jack8745 Posted January 16, 2009 Author Report Share Posted January 16, 2009 Auto up and down on newer cars is done with two things which we don't readily have: hall-effect sensors in (or rather, near) the motors and limit switches (I believe).The auto-down module on 850s and S70s is an interesting device in that it senses a spike in current to detect motor stall. You can test this by putting the window in auto down mode and then grabbing it with both hands to keep it from going down. It should stall out and the relay will click off, thinking it reached the bottom.You can use a second module for the passenger side though (as well as both rears).which relay is it ? Link to comment Share on other sites More sharing options...
Serge Posted January 16, 2009 Report Share Posted January 16, 2009 which relay is it ?Inside the center console, right behind the master window switch. When you press the driver's window down you can hear it click. Link to comment Share on other sites More sharing options...
Gage Posted January 17, 2009 Report Share Posted January 17, 2009 has anyone converted the master window switch to have a dual auto down feature for front windows?plus i know i have seen many of you with the rear window switches illuminated. i cant find how to do itplease helpthanks JackI make the rear switches 25.00 shipped for the pair LMK Link to comment Share on other sites More sharing options...
z31jaime Posted January 17, 2009 Report Share Posted January 17, 2009 wait so 850's arnt supposed to have dual auto down windows? mine has it. i just push it and both of em go by themselves, its kinda a pain, cause sometimes i wanna check the window i gotta stop it when its on its way down. Link to comment Share on other sites More sharing options...
Jack8745 Posted January 17, 2009 Author Report Share Posted January 17, 2009 I make the rear switches 25.00 shipped for the pair LMKi'll rather do it myself Link to comment Share on other sites More sharing options...
Gage Posted January 17, 2009 Report Share Posted January 17, 2009 i'll rather do it myself Ohh Ok Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 20, 2009 Report Share Posted January 20, 2009 Get an aftermarket window module from DEI and it will be one touch up AND down... DEI - 530T Link to comment Share on other sites More sharing options...
msestina Posted January 23, 2009 Report Share Posted January 23, 2009 Get an aftermarket window module from DEI and it will be one touch up AND down... DEI - 530TThanks! I like the One touch Up/Down plus this unit does auto vent position. Have you installed one? I see some brand new DEI 530s on eBay ~ $50. Link to comment Share on other sites More sharing options...
PaperToast Posted January 26, 2009 Report Share Posted January 26, 2009 this seems like an interesting ideawould the procedure be the same for a x70? Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 28, 2009 Report Share Posted January 28, 2009 Thanks! I like the One touch Up/Down plus this unit does auto vent position. Have you installed one? I see some brand new DEI 530s on eBay ~ $50.I have a module from a different company. It only does it when using an alarm.But the DEI is awesome... no alarm needed. I'm thinking about changing my modules to DEI's to get the auto down/up feature in the car. Make sure that it's a 530 and NOT a 529. Link to comment Share on other sites More sharing options...
