Cal3thousand Posted January 14, 2009 Report Share Posted January 14, 2009 I have 2.5" piping and a suitcase Magnaflow in the stock location. I want it to be quieter, so I'm adding a muffler.Quick question:Is there ANY reason why I would go with the 14851 over the 14835?14835:Inlet/Outlet Size: 3in./4in.Body Shape: 5in.x8in. OvalCore Size: 3in.Body Length: 14in.14851:Inlet/Outlet Size: 2.25in./4in.Body Shape: 5in.x8in. OvalCore Size: 2.5in.Body Length: 14in. Link to comment Share on other sites More sharing options...
nolanator Posted January 14, 2009 Report Share Posted January 14, 2009 what?! what!!! ...oh this isnt at all what i thought it would be...that title is deceiving anyway obviously if the difference is in the diameter the larger will offer less restriction, but you will have to step up your piping Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 14, 2009 Author Report Share Posted January 14, 2009 what?! what!!! ...oh this isnt at all what i thought it would be...that title is deceiving anyway obviously if the difference is in the diameter the larger will offer less restriction, but you will have to step up your pipingWell this muffler is on at the very end.... so its either stepping down to 2.25", which seems illogical to me, or flaring out the 2.5" pipe to meet the 3" inlet.I'm leaning towards the 3" inlet and core Link to comment Share on other sites More sharing options...
MavericK41 Posted January 14, 2009 Report Share Posted January 14, 2009 what?! what!!! ...oh this isnt at all what i thought it would be...that title is deceiving LMFAO!! :lol: Link to comment Share on other sites More sharing options...
mune237 Posted January 14, 2009 Report Share Posted January 14, 2009 I'm sure they have a 2.5" inlet muff that should work??????EDIT: Then again maybe not...go with the 3" inlet 14835 Link to comment Share on other sites More sharing options...
nolanator Posted January 14, 2009 Report Share Posted January 14, 2009 go 3" its an all around improvement Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 14, 2009 Author Report Share Posted January 14, 2009 Done...BTW nolanator, we should meet up some time. I used to live in VTA and SB, so I'm up there every once in a while. Link to comment Share on other sites More sharing options...
nolanator Posted January 14, 2009 Report Share Posted January 14, 2009 Done...BTW nolanator, we should meet up some time. I used to live in VTA and SB, so I'm up there every once in a while.yea that'd be great. there's a few others around this area too. let me know when you'll be around here next? Link to comment Share on other sites More sharing options...
sconeman Posted January 14, 2009 Report Share Posted January 14, 2009 Done...BTW nolanator, we should meet up some time. I used to live in VTA and SB, so I'm up there every once in a while.why make it harder to install? It's not going to make any difference if the rest of your system is 2.5" get a 2.5" in with a 3" or 4" out. Link to comment Share on other sites More sharing options...
nolanator Posted January 14, 2009 Report Share Posted January 14, 2009 Cal are you doing the work yourself or is a shop going to do it? Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 14, 2009 Author Report Share Posted January 14, 2009 why make it harder to install? It's not going to make any difference if the rest of your system is 2.5" get a 2.5" in with a 3" or 4" out.Can't find one to my liking... want to help?... just kidding... to late anyways... ordered it 125 shippedCal are you doing the work yourself or is a shop going to do it?Not sure... my cousin could help since he's got a welder, but I think I want the same shop that did it last time to do this part too. Should be $50 to install, since the have to cut off the old tip, and flare the pipe and weld. Link to comment Share on other sites More sharing options...
samadkins29 Posted January 15, 2009 Report Share Posted January 15, 2009 You said you wanted it to be less noisy. Adding a 3" muffler with a 4" outlet will be the opposite. All magnaflows are are glasspacks. Eventually the glasspack gets burned out. You want less noise, then you need a smaller opening. Link to comment Share on other sites More sharing options...
7 VII 7 Posted January 15, 2009 Report Share Posted January 15, 2009 why not 2.5 in and 2.5 out since you have 2.5 piping? :arob: Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 15, 2009 Author Report Share Posted January 15, 2009 why not 2.5 in and 2.5 out since you have 2.5 piping? Kind find one I like... like i said earlier.You said you wanted it to be less noisy. Adding a 3" muffler with a 4" outlet will be the opposite. All magnaflows are are glasspacks. Eventually the glasspack gets burned out. You want less noise, then you need a smaller opening.But currently, I have only one muffler in the stock location going to a tip. I'm adding this muffler at the end. Are you saying it won't have any sound reduction effects? Link to comment Share on other sites More sharing options...
nolanator Posted January 15, 2009 Report Share Posted January 15, 2009 Kind find one I like... like i said earlier.But currently, I have only one muffler in the stock location going to a tip. I'm adding this muffler at the end. Are you saying it won't have any sound reduction effects?yes it will. i think what he is trying to say is if you were to do everything you want to do with smaller piping as opposed to larger piping, the effects would be quieter, but regardless of which route you take, you are going to produce less noise with an additional muffler than you are now Link to comment Share on other sites More sharing options...
