gray1g Posted October 24, 2004 Report Share Posted October 24, 2004 I have a 95 850 Turbo Wagon. My question is how do you know if you have an air pump? I looked in my fuse box and there is not a fuse for it. I looked at my friends 94 850 turbo and he has a fuse in his box. My question is again, how do you know if you have a air pump??? Thanks in advance Link to comment Share on other sites More sharing options...
Bay13 Posted October 24, 2004 Report Share Posted October 24, 2004 Look to see if there is one there. The below link shows you how to replace it so it should help you to find it if it's there.http://www.volvospeed.com/Repair/airpump1.htm Link to comment Share on other sites More sharing options...
gray1g Posted October 24, 2004 Author Report Share Posted October 24, 2004 Look to see if there is one there. The below link shows you how to replace it so it should help you to find it if it's there.http://www.volvospeed.com/Repair/airpump1.htm←I don't see it. I guess that means I do not have one?? Did all Volvos come with one or only certain models? Link to comment Share on other sites More sharing options...
Bay13 Posted October 24, 2004 Report Share Posted October 24, 2004 Only certian cars have an air pump. Variables are, Air pump, EGR. You could have none or one or both, it all depends on how it was set up smog wise.http://www.volvospeed.com/Repair/airpump1.htmThe above link is for the EGR cleaning so you can check it out if you want. :) Link to comment Share on other sites More sharing options...
