Jack8745 Posted January 23, 2009 Report Share Posted January 23, 2009 i replaced the 2 main coolant hoses a while back. now i want to replace the cooant hoses from the t-stat to tank and tank to turbo. i cant find the thread that has their sizes does anyone know, i dont want to remove them to measure thanks Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted January 23, 2009 Report Share Posted January 23, 2009 i replaced the 2 main coolant hoses a while back. now i want to replace the cooant hoses from the t-stat to tank and tank to turbo. i cant find the thread that has their sizes does anyone know, i dont want to remove them to measure thanks6842984 bottom tank hose and 9135267 vent from the tank top hose. Not positive on the size though. Link to comment Share on other sites More sharing options...
steve s Posted January 23, 2009 Report Share Posted January 23, 2009 i think i used the 8mm silicone heater hose for the return at the top, and a 10 mm silicone heater hose for the turbo one that's nearly on top of the heat shield.. Link to comment Share on other sites More sharing options...
--Aaron-- Posted January 23, 2009 Report Share Posted January 23, 2009 i think i used the 8mm silicone heater hose for the return at the top, and a 10 mm silicone heater hose for the turbo one that's nearly on top of the heat shield..+1I used 8mm securely clamped on both ends for the tank.For the tank to turbo the only section of hose is roughly ~4 in. or so long....I wouldn't order more than a foot really unless there's other places you can use the 10mm. Unless you want to pick up ~4 ft. and replace your brake booster line as well....just a thought so you don't end up with a bunch of wasted product. Link to comment Share on other sites More sharing options...
Jack8745 Posted January 23, 2009 Author Report Share Posted January 23, 2009 +1I used 8mm securely clamped on both ends for the tank.For the tank to turbo the only section of hose is roughly ~4 in. or so long....I wouldn't order more than a foot really unless there's other places you can use the 10mm. Unless you want to pick up ~4 ft. and replace your brake booster line as well....just a thought so you don't end up with a bunch of wasted product.thanks guys, i always get WAY more hoses then whats needed that way i always have something on hand Link to comment Share on other sites More sharing options...
