ajhehr Posted January 29, 2009 Report Share Posted January 29, 2009 wow deja vu... weve been here beforehttp://volvospeed.com/vs_forum/lofiversion...php/t93249.html100' will get you to the rear axle at least. in conclusionwrapping quiets drone, adds small amounts of power (arguably), and keeps LARGE amounts of heat away from anything and everything.traps moisture? yes, enough to damage and cause failure??? i have never seen any evidence of it, although it may... but even in Oregon I never had problemsmild steal up north? no...Stainless? yes?you be the judge. from this day on I will always wrap my exhausts... all the way back. and those that have experience with my wrap, I think (hope) agree. Link to comment Share on other sites More sharing options...
matt b Posted January 29, 2009 Report Share Posted January 29, 2009 Pretty sure I'll do this after I finally get Joseph's old exhaust welded onto the wagon. And yes, salt is definitely an issue here. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 29, 2009 Report Share Posted January 29, 2009 wow deja vu... weve been here beforehttp://volvospeed.com/vs_forum/lofiversion...php/t93249.html100' will get you to the rear axle at least. .I think I'll start w/ the DP - for me, the main reason is to protect the front driveshaft CV - if it really drones, I'll consider going further back. Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted January 29, 2009 Report Share Posted January 29, 2009 wow deja vu... weve been here beforehttp://volvospeed.com/vs_forum/lofiversion...php/t93249.html100' will get you to the rear axle at least. in conclusionwrapping quiets drone, adds small amounts of power (arguably), and keeps LARGE amounts of heat away from anything and everything.traps moisture? yes, enough to damage and cause failure??? i have never seen any evidence of it, although it may... but even in Oregon I never had problemsmild steal up north? no...Stainless? yes?you be the judge. from this day on I will always wrap my exhausts... all the way back. and those that have experience with my wrap, I think (hope) agree.Dammit aaron, you beat me to it. I was just going to link up that thread. Gold star for you To those who think SS will mean you are rust proof, stainless is called that because it resists rusting better than regular steel; however it is not stainproof. Link to comment Share on other sites More sharing options...
JohnR352 Posted January 29, 2009 Report Share Posted January 29, 2009 Dammit aaron, you beat me to it. I was just going to link up that thread. Gold star for you To those who think SS will mean you are rust proof, stainless is called that because it resists rusting better than regular steel; however it is not stainproof.Correct of course, and I've learned that different qualities of SS resist better then others. Most high quality DP's will resist pretty well. I wrapped my DP and then sealed it with heat wrap sealant (paint really). I used the Inferno wrap (3000 degree) wrap and then sprayed it to keep out the water. Link to comment Share on other sites More sharing options...
the commissar! Posted January 29, 2009 Report Share Posted January 29, 2009 I'm going to try this in aluminum Product DescriptionThe High Temperature (HT) Silicone Coating provides lasting protection for any hot surface up to 1500 degrees. DEI recommend the use of this coating with their exhaust wrap because it seals the material and provides lasting protection from oil, dirt and road grime. Don't limit the use to exhaust header wrap, this products works well on headers, blocks, starters and even on your grill at home. * Heat protection up to 1500 degrees * Seals and protects exhaust wrap * Many uses around the home and shop * One can enough for V8 headers Used correctly on clean dry wrap should significantly reduce the rusting problem. Wrapped my DP last night down to just past cat. It's sitting under a celing fan drying as we type. Link to comment Share on other sites More sharing options...
SRTthis Posted January 29, 2009 Report Share Posted January 29, 2009 do you spray the pipe or the wrap? im thinking about wrapping the down pipe before it goes on. it should be here tuesday im thinking ill get a 50' roll and go as far as that takes me Link to comment Share on other sites More sharing options...
the commissar! Posted January 29, 2009 Report Share Posted January 29, 2009 do you spray the pipe or the wrap? im thinking about wrapping the down pipe before it goes on. it should be here tuesday im thinking ill get a 50' roll and go as far as that takes meEither or both, they recommend on the wrap for protection hence my comments but you can use it alone. I got the 100 foot kit from Summit for ~$85 including shipping but I’m doing 2 cars. 50 foot will get you 10 feet on 3” straight pipe. Depending on # of bends it will be less. Then you’ll need fasteners. GL Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted January 31, 2009 Report Share Posted January 31, 2009 Unwrap a pipe that has been wrapped for a while and you'll change your mind about wrapping it. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted January 31, 2009 Report Share Posted January 31, 2009 Unwrap a pipe that has been wrapped for a while and you'll change your mind about wrapping it.Why do you say that?What have you seen? Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted January 31, 2009 Report Share Posted January 31, 2009 Why do you say that?What have you seen?I'm going to go waaaay out in left field here and take a guess. I bet he saw some sort of rust/corrosion. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted January 31, 2009 Report Share Posted January 31, 2009 well I don't believe that any rust or corrosion could lead the pipe in failure in short time,the thing is,are the advantages more than the disadvantages(the one until now).Personally I will wrap at least my downpipe,because I don't want to burn everything around there. Link to comment Share on other sites More sharing options...
the commissar! Posted February 1, 2009 Report Share Posted February 1, 2009 unless you have a cheap mild steel exhaust or you over wrap it (trap too much heat under wrap), it should not be much of a problem. I think if you use a properly prepared and applied quality high temp paint, to prepare the surface for the properly installed wrap and silicone coating you should be GTG for a long time. I think it is a waste of time to prepaint but my catback came with it so...I'll compare how long it lasts compared to my naked wrapped downpipe. Link to comment Share on other sites More sharing options...
