elfnmagik Posted January 28, 2009 Report Share Posted January 28, 2009 I've got 175k on the clock and have had most all the major surgeries (rear main, suspension, PVC, timing/pump, axles, etc.). The motor's never had open heart though and blood pressure has always been 10 or 5w-40 Pen-dino. I did a tran flush at 90k, the water torture/Seafoam plus added to the tank at 132K, and fuel filter (2nd) just the other day. I'm prolly gonna do both the flush and torture/seafoam again along with plugs/wires/dist/rotor and I've got an old bottle of Amsoil Engine Flush I've never used and was considering that too. What other additives/cleaners and/or maintenance would you folks recommend to keep the ticker in tip-top? Link to comment Share on other sites More sharing options...
elfnmagik Posted January 28, 2009 Author Report Share Posted January 28, 2009 Ooops, ment for this to be in "98 and Prior". Also, forgot to mention it's a '97 850 N/A Link to comment Share on other sites More sharing options...
(n)A-GAME Posted January 28, 2009 Report Share Posted January 28, 2009 seafoam is enough.and why is there a TM symbol in your post title? :huh: Link to comment Share on other sites More sharing options...
elfnmagik Posted January 28, 2009 Author Report Share Posted January 28, 2009 No real reason, just used on some other forums. Bother? Link to comment Share on other sites More sharing options...
flyfishing3 Posted January 28, 2009 Report Share Posted January 28, 2009 moved it for you. Link to comment Share on other sites More sharing options...
elfnmagik Posted January 28, 2009 Author Report Share Posted January 28, 2009 'preciate it. Link to comment Share on other sites More sharing options...
Keaton85 Posted January 28, 2009 Report Share Posted January 28, 2009 It's an N/A so no real need to bother messing with anything. If the oil changes have been done correctly at an interval you feel comfortable with then you are probably all set. Link to comment Share on other sites More sharing options...
EricF Posted January 28, 2009 Report Share Posted January 28, 2009 I've heard good things about AutoRX... Link to comment Share on other sites More sharing options...
elfnmagik Posted January 28, 2009 Author Report Share Posted January 28, 2009 I know it's running rich, burns about a quart every 4K, and noticed a good bit of carbon around the inlets on the manifold/head, but other than that, runs pretty good. Link to comment Share on other sites More sharing options...
elfnmagik Posted January 28, 2009 Author Report Share Posted January 28, 2009 So what are the thoughts on switching to synthetic at this age? Would it clean things up a bit? Link to comment Share on other sites More sharing options...
johnloves850's Posted January 28, 2009 Report Share Posted January 28, 2009 with dino oil you shouldn't let it go past 2500-3k milesso you've been setting yourself up for some nice sludge action lolyes yes yes, switch to synthetic as soon as you possibly cani use a k&n oil filter, but everyone here likes mann or OEM filtersthey all do the same thing, although i have a little more piece of mind using a k&n because of their filter element researchit's your call though on the filter, as far as switching to synthetic...this is not your call haha, switch to synthetic, there is no option lolgood luck Link to comment Share on other sites More sharing options...
Keaton85 Posted January 28, 2009 Report Share Posted January 28, 2009 Where do you come up with this information?It's not even correct..More to the point do YOU know what the difference between synthetic and non-synthetic is and why use one vs. the other in a given situation? Link to comment Share on other sites More sharing options...
sconeman Posted January 29, 2009 Report Share Posted January 29, 2009 switching to synthetic this late in the game is typically not recommended Link to comment Share on other sites More sharing options...
Crabolsky850 Posted January 29, 2009 Report Share Posted January 29, 2009 I'm prolly gonna do both the flush and torture/seafoam again along with plugs/wires/dist/rotorIve seen this "prolly" on this board a handful of times..Why? Link to comment Share on other sites More sharing options...
brick-a-brac Posted January 29, 2009 Report Share Posted January 29, 2009 switching to synthetic this late in the game is typically not recommended+1,000,000Unless you like your garage floor all oily. Link to comment Share on other sites More sharing options...
