Jack8745 Posted February 1, 2009 Report Share Posted February 1, 2009 damn it, i just spent 1 and 1/2 hours under the car looking for this a "bump" I'm hearing. after rasing and lowering the car couple of times I cant find nothing loose. Whenever I go over a speed bump or make sharp left turns (does not do it when i turn right) i hear a clunk/bump from the passenger front area. Only does it when the car is moving I didn't feel like removing my struts to check it. i'll do it if i have to I got eibach and bilsteins on for 2~3 years now. replaced the strut bushings then also.last time (and first) i would hear bumps all the time, it was easy to tell the noises where coming from the struts any serious suggesrions ? <_< Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 1, 2009 Report Share Posted February 1, 2009 Check for balljoint play and worn control arm bushings. Try grabbing the wheel at 9 and 3 olcok and 12 and 6 to see if it has play and/or can recreate the knock. Sounds like a control arm or tierod problem to me. Link to comment Share on other sites More sharing options...
Jack8745 Posted February 1, 2009 Author Report Share Posted February 1, 2009 Check for balljoint play and worn control arm bushings. Try grabbing the wheel at 9 and 3 olcok and 12 and 6 to see if it has play and/or can recreate the knock. Sounds like a control arm or tierod problem to me.did the grab wheel method. controll arm bushing also look great. i dont think i checked the TRE. will check tomorrow with wheel offthanks Link to comment Share on other sites More sharing options...
PaperToast Posted February 1, 2009 Report Share Posted February 1, 2009 got some dead endlinks? Link to comment Share on other sites More sharing options...
the commissar! Posted February 2, 2009 Report Share Posted February 2, 2009 how are your spring seats? Mine would make a clunk/bump noise on speedbumps as you indicated prior to replacement. Link to comment Share on other sites More sharing options...
cn90 Posted February 2, 2009 Report Share Posted February 2, 2009 My lates post is from today Feb. 01, 2009:http://volvospeed.com/vs_forum/index.php?showtopic=111383The bottom line about the Front End Suspension is that: I learned the Front Suspension hard way:- I first replaced the Outer Tierods 12 months ago- Sway Bar End Links 6 months ago- Control Arms (Volvo OEM) 4 months ago- Then CV Rubber Boots 2 months ago.- Today, I just replaced my Front Strut! So this was my 5th time poking my head in that area!So if you have more than 90-100K miles and if you plan to keep your car for another 80-100K, then consider doing ALL of the items I mentioned at the same time, on the long run, you save money/labor/alignment costs. Link to comment Share on other sites More sharing options...
AlvinL Posted February 2, 2009 Report Share Posted February 2, 2009 Where did you get your end links? Check the one on the right side. That's my first thought too. Link to comment Share on other sites More sharing options...
