nolanator Posted February 3, 2009 Report Share Posted February 3, 2009 yea i know this is the second thread on this, but the first one i had i put up some misinformation, so i had a few questions.i just got this in the mail.and thankfully it is not nearly as big as i thought it was (ps. mucho mango = awesome)both the compressor and the turbine are A/R .60 what turbine size could i actually switch to (it's a T4 now, it would obviously be switched to T3 to run an internal wastegate) if i wanted to hypothetically use something like this, or is it just too damn big.btw i'm 90% sure i'm just going to end up selling it in the end, but the info would be very helpful Link to comment Share on other sites More sharing options...
sconeman Posted February 3, 2009 Report Share Posted February 3, 2009 I thought you were going with a 16t Link to comment Share on other sites More sharing options...
bum2kev Posted February 3, 2009 Report Share Posted February 3, 2009 what model garrett is it? Link to comment Share on other sites More sharing options...
EricF Posted February 3, 2009 Report Share Posted February 3, 2009 yea i know this is the second thread on this, but the first one i had i put up some misinformation, so i had a few questions.i just got this in the mail.and thankfully it is not nearly as big as i thought it was (ps. mucho mango = awesome)both the compressor and the turbine are A/R .60 what turbine size could i actually switch to (it's a T4 now, it would obviously be switched to T3 to run an internal wastegate) if i wanted to hypothetically use something like this, or is it just too damn big.btw i'm 90% sure i'm just going to end up selling it in the end, but the info would be very helpfulUnless it's a 46 trim T04E, or one of the smaller T04B, a standard T3 turbine wheel is going to be pretty mis-matched. Chances are that it's a 50, 57, or 60 trim T04E... In that case, you're going to probably want a stage 3 wheel with either a .48 or .63 T3 turbine housing and 5-bolt outlet.Or the Turbonetics equivalents... http://www.turboneticsinc.com/products/ind...;category_id=36 Turbine wheelAnd http://www.turboneticsinc.com/products/ind...;category_id=40 Turbine housingsYou're at $500 there though. I don't know the Garrett part numbers, maybe someone does... I'd guess probably $400 new though. Alternately, you could pick up a used crap E-bay China T3/T4 turbo, and pirate the turbine housing and wheel, send it off to be assembled and re-balanced and come out with a nice turbo for not too much extra. Link to comment Share on other sites More sharing options...
GeraldJ Posted February 3, 2009 Report Share Posted February 3, 2009 Stop buying random turbos and just buy what you need. In the end you will be much happier and spent a lot less money.Call up turbonetics and just order the t3/t04e-50 with a .48 stage 3, 5 bolt. Then call atp and get the uiwg. When your done you have spent about $900 and then your done with it. All you need then is a custom downpipe and some oil/water fittings. Unless your going with rods and pistons in your motor then go a little bigger on the t04e side. something like a 60 trim would be nice at 20+psi :D Link to comment Share on other sites More sharing options...
nolanator Posted February 3, 2009 Author Report Share Posted February 3, 2009 Stop buying random turbos and just buy what you need. In the end you will be much happier and spent a lot less money.Call up turbonetics and just order the t3/t04e-50 with a .48 stage 3, 5 bolt. Then call atp and get the uiwg. When your done you have spent about $900 and then your done with it. All you need then is a custom downpipe and some oil/water fittings. Unless your going with rods and pistons in your motor then go a little bigger on the t04e side. something like a 60 trim would be nice at 20+psi you act like i have a bad habit of buying random turbos...this is the only other one besides the the 15g that i got for free I thought you were going with a 16t refer to the last line of my original post Link to comment Share on other sites More sharing options...
