VAVolvo Posted October 27, 2004 Report Share Posted October 27, 2004 I have currently installed in my 850 NA a K&N high flow cone filter intake, Iridium plugs, most of Stage 0 stuff (except for the plug wires) and will be getting a new exhaust with a high flow cat, flow master muffler and I think 3" piping. Then after that, I'm getting an ECU upgrade with SpeedtuningUSA which will add another 16 HP. I was wondering if someone could give me a ball park estimate of the HP that I will have when I'm done, and if there is any other upgrade that I left out?Thankyou! Link to comment Share on other sites More sharing options...
FINN Posted October 27, 2004 Report Share Posted October 27, 2004 I dont think running a 3" exhaust on a NA is necessary. Link to comment Share on other sites More sharing options...
VAVolvo Posted October 27, 2004 Author Report Share Posted October 27, 2004 Could be 2 1/2"...I think...yeah...pretty sure....but that is beside the point. Link to comment Share on other sites More sharing options...
StickThatClutch Posted October 27, 2004 Report Share Posted October 27, 2004 If you go with like a 2.5" exhuast I think you can net around 8-10 whp. If you go with the 3" I think you'll see worse number due to less backpressure.Good luck. Link to comment Share on other sites More sharing options...
VAVolvo Posted October 27, 2004 Author Report Share Posted October 27, 2004 Ok, ok...2 1/2"...ENOUGH about the exhaust...Anything else? Seriously...with a PROPER exhaust, intake, ECU upgrade...what is the added HP? Link to comment Share on other sites More sharing options...
JDELUNA Posted October 27, 2004 Report Share Posted October 27, 2004 It will be hard to estimate yor HP as the HP figures that manufactures of the mods can not be added up to a single figure. The reason being is that each HP figure that they give may be measured at a certain RPM. Example is that let us pretend that K&N claims that by adding their intake it will give you 10HP gain, but this is at 5500rpm, the Speedtuning chip may claim 15HP gain, but this is at 6000rpm, Exhaust gives you 7HP but at 3500rpm. As you can see you can not just simply add all these numbers up and get a figure. The best thing to do is to get your car dynoed. :) Link to comment Share on other sites More sharing options...
StickThatClutch Posted October 27, 2004 Report Share Posted October 27, 2004 I say 8-10 peak fwhp. Maybe some gains as high as 15 in the midrange. Which isn't too bad. Link to comment Share on other sites More sharing options...
VAVolvo Posted October 27, 2004 Author Report Share Posted October 27, 2004 It will be hard to estimate yor HP as the HP figures that manufactures of the mods can not be added up to a single figure. The reason being is that each HP figure that they give may be measured at a certain RPM. Example is that let us pretend that K&N claims that by adding their intake it will give you 10HP gain, but this is at 5500rpm, the Speedtuning chip may claim 15HP gain, but this is at 6000rpm, Exhaust gives you 7HP but at 3500rpm. As you can see you can not just simply add all these numbers up and get a figure. The best thing to do is to get your car dynoed. ←Thankyou, thankyou very much...makes sense, makes total sense. I'll look into the dynoed thing, got any info on that? Link to comment Share on other sites More sharing options...
turbor850 Posted October 27, 2004 Report Share Posted October 27, 2004 8-10 whpfrom an exhaust ? ? ? I don't even think turbo 850's get that . . . .my guess is 168 stock + exhaust/intake/ecu = 190 . . . . Link to comment Share on other sites More sharing options...
StickThatClutch Posted October 27, 2004 Report Share Posted October 27, 2004 from an exhaust ? ? ? I don't even think turbo 850's get that . . . .my guess is 168 stock + exhaust/intake/ecu = 190 . . . .←That was for everything, chip/exhuast/intake/etc...Turbos get around 10 whp from the cat back. I dyno'ed my S60 it netted 11.7 whp peak with some ranges seeing almost as much as 20whp. Link to comment Share on other sites More sharing options...
JDELUNA Posted October 27, 2004 Report Share Posted October 27, 2004 Thankyou, thankyou very much...makes sense, makes total sense. I'll look into the dynoed thing, got any info on that?←Well seing that you are in Richmond, Virginia right ?? I looked up places that had DynoJet dynos, you will need to call them to see if they are open to the public, how much it will cost, etc. Good luck and God Bless. Performance Autosport12927 Plaza DriveRichmond 23233Tel: 804-784-8851 Rosen Autosport3211 Lanvale Ave.Richmond 23230Tel. 804-421-9222 Urban Mechanical9115 Three Chopt RdRichmond 23229Tel. 804-798-8340Also the best thing to do is dyno yor car completely STOCK before you make any mods to it so that you will have a baseline, then after the mods to see if any gains and how much. Link to comment Share on other sites More sharing options...
VAVolvo Posted October 27, 2004 Author Report Share Posted October 27, 2004 Well seing that you are in Richmond, Virginia right ?? I looked up places that had DynoJet dynos, you will need to call them to see if they are open to the public, how much it will cost, etc. Good luck and God Bless. Performance Autosport12927 Plaza DriveRichmond 23233Tel: 804-784-8851 Rosen Autosport3211 Lanvale Ave.Richmond 23230Tel. 804-421-9222 Urban Mechanical9115 Three Chopt RdRichmond 23229Tel. 804-798-8340Also the best thing to do is dyno yor car completely STOCK before you make any mods to it so that you will have a baseline, then after the mods to see if any gains and how much.←Thanks very much, this is some good info and I think I already know where one of them is. PEACE! Link to comment Share on other sites More sharing options...
prasamin Posted October 27, 2004 Report Share Posted October 27, 2004 That was for everything, chip/exhuast/intake/etc...Turbos get around 10 whp from the cat back. I dyno'ed my S60 it netted 11.7 whp peak with some ranges seeing almost as much as 20whp.←ummm, s60.....850 NA....i think those cars are pretty different...i would say expect a MAX of 25 hp gain when all is said and done, but realistically maybe 20 hp....if you had a hpt, then i'd put you at a good 40 hp gain with all that. Link to comment Share on other sites More sharing options...
volvo4lif3 Posted October 27, 2004 Report Share Posted October 27, 2004 i would like to say that stock plain jane 850's had 150 hp. My dad had an 97 n/a 850 , that was until he hit into an 18 wheeler, and survived :) Link to comment Share on other sites More sharing options...
Karlson Posted October 27, 2004 Report Share Posted October 27, 2004 If you go with like a 2.5" exhuast I think you can net around 8-10 whp. If you go with the 3" I think you'll see worse number due to less backpressure.Good luck.←it is funny picture dude :D Link to comment Share on other sites More sharing options...
