blazen244 Posted October 27, 2004 Report Share Posted October 27, 2004 <_< Do any body know where I can get my turbo pipe polished and my thottle body bored out and polished Second question is. Is there any piont to having the exhaust manifold polished and or ported if posible Link to comment Share on other sites More sharing options...
ROB @ VMS Posted October 27, 2004 Report Share Posted October 27, 2004 Vms Ported Polished Manifolds.We can polish anything you want to a mirror finish. Also we do throttle bodies as well. Brent is doing one with us at the moment if you would like to get some feedback with others that are doing the same. Link to comment Share on other sites More sharing options...
ginkof Posted October 27, 2004 Report Share Posted October 27, 2004 just curious but how is porting and polishing done? especially around all those weird turns and stuff? ive heard that this gew that eats away at metal is pumped through the pipes and that ports it... myth? or true? Link to comment Share on other sites More sharing options...
ROB @ VMS Posted October 27, 2004 Report Share Posted October 27, 2004 We use special bits and tools to do the work. For a really good job it takes awhile to do it. Link to comment Share on other sites More sharing options...
Nebor Posted October 27, 2004 Report Share Posted October 27, 2004 just curious but how is porting and polishing done? especially around all those weird turns and stuff? ive heard that this gew that eats away at metal is pumped through the pipes and that ports it... myth? or true?←You're thinking of what they call 'flowing.' Also called extrusion honing. They use a clay based emulsifier and pump it back and forth through the manifold. This eats away at the inside and bores it out, as well as smooths it.Just curious, Rob, do your manifold's require a core, or does the customer supply the manifold to be worked on? And do you have any of those available with one more runner? ;) Link to comment Share on other sites More sharing options...
blazen244 Posted October 27, 2004 Author Report Share Posted October 27, 2004 Should I call and get a price list for the port and polishing for the manifold or can you send me a price list Link to comment Share on other sites More sharing options...
98BRICK Posted October 27, 2004 Report Share Posted October 27, 2004 Do any body know where I can get my turbo pipe polished and my thottle body bored out and polished Second question is. Is there any piont to having the exhaust manifold polished and or ported if posible← TB Overbore Link to comment Share on other sites More sharing options...
theunderlord Posted October 27, 2004 Report Share Posted October 27, 2004 BTW... the turbo intercooler pipe polising is a couple hour do it yourself project.. Greg (Gdogg) did a really nice write up on it a while back... Link to comment Share on other sites More sharing options...
ROB @ VMS Posted October 27, 2004 Report Share Posted October 27, 2004 You're thinking of what they call 'flowing.' Also called extrusion honing. They use a clay based emulsifier and pump it back and forth through the manifold. This eats away at the inside and bores it out, as well as smooths it.Just curious, Rob, do your manifold's require a core, or does the customer supply the manifold to be worked on? And do you have any of those available with one more runner? ←Hey yes we require a core back and we can send you one no problem, at the moment we do not have any 6cly manifolds in at the moment but can port on no problem. Link to comment Share on other sites More sharing options...
Figawi Posted October 27, 2004 Report Share Posted October 27, 2004 is it possible to bore a throttle body myself? what is involved? Link to comment Share on other sites More sharing options...
ROB @ VMS Posted October 27, 2004 Report Share Posted October 27, 2004 If you know what you are doing and have the equitment to do it. Link to comment Share on other sites More sharing options...
WhiteT5 Posted October 27, 2004 Report Share Posted October 27, 2004 I did it myself w/ a throttle body. I went through several dremel things. You have to use the ones that are like within' a mm size of the larger side of the TB. They're the dark colored ones. It took a coupla hours to actually get it bored out. Then you can use a polishing wheel of the same size to get it to a mirror shine. It ended up about 5 mm larger in diameter. I had to get a new throttle plate made by a machine shop. I also had them examine the throttle body itself and make sure it was perfectly round and stuff. The new throttle plate seals perfectly inside the housing and there are no leaks or irregularities. It's not on the car yet. I'm just going to replace it whenever I clean my EGR valve next. I am however interested in having my intake manifold ported and polished, which is obviously not doable by myself. Have you ported and polished intake manifolds before Rob? Link to comment Share on other sites More sharing options...
ROB @ VMS Posted October 27, 2004 Report Share Posted October 27, 2004 Yes we do, also very soon here we will have custom intake manifolds for both turbo and NA motors. Link to comment Share on other sites More sharing options...
PyROTech Posted October 28, 2004 Report Share Posted October 28, 2004 dont ya all love the helpfull vendors on this site, gota say i like the responses, very pro! Link to comment Share on other sites More sharing options...
