Looking For Timing Belt Tips
mmmmmmm
It just seems so f-ing tight and the fact that the tensioner pulley has to be completely un-tensioned for ANYTHING to go makes me think it is too short.
But that's exactly the idea.. the tensioner isn't taking up all that much slack. The belt will be tight when you first put it on because it will stretch out a small amount shortly after you put it on. Don't give up, you can get it. B)
  • Replies 157
there's 150 posts on how to replace a timing belt? Maybe this shouldn't be a DIY for the original poster :P
put tensioner pulley in (if replaced), put tensioner in there with pin still in. route belt from crank, around tensioner pulley, around water pump, pull upwards hard to make sure you're hooked on the crank, slide it on the idler pulley, now the next is preference. Volvo tells you to put on the exhaust first then the intake, I pull upwards hard, make the teeth line up on the intake, then flip it on the exhaust.
If you're having this much trouble, why not bring it to a shop? They'll charge you probably 1 1/2 hours... plus if they screw it up, they buy it. If you screw it up, you'll be starting a post "Looking for Head Removal Tips"
Oh and you don't need a cam lock tool.
The only time I've used a cam lock tool is when I'm either:
#1: Taking off a VVT pulley
#2: Putting the valve cover back on
Other than that, if the cam moves on you (rarely happens anyways) just use your man force and move the cam back to TDC by hand.
doing the hydraulic tensioner now... then routing the belt then testing, then pulling the pin... lets hope it does not go boom
Fail. You made the same mistake that I did. Bolt the hydraulic tensioner on AFTER the belt is routed. There will be plenty of slack. If there isn't, then the belt is hung up around the crank pulley.
Coming from experience? I've only done 100+ timing belts, and I've always bolted the tensioner on first...
But you know, I'm sure you've done many too :rolleyes:
I have finally been able to get the belt tight around the intake side and slipped it on the exhaust to the water pump and then the tensioner...
the intake side is not lining upr correctorly because if I want to keep it tight the teeth in the belt and the teeth in the intake CAM do not fall into each other so I have to move the intake CAm which makes it out of line... grrr
Ok, so this is as good as I have got with the tension really tight on the crank to intake CAM and some slack from the exhaust to the tensioner
Intake side (it is within the triangle but not sure if it needs to be EXACTLY lined up
here is the exhaust side
the crank is spot on with the line on the oil pump... all I have to do is pull the pin but I wanted to make sure those will be fine
i havent done the timing belt before but I thought I read somewhere that it has to be exact and not even off one tooth or you will have problems? Maybe im wrong. Hopefully someone will chine in to clarify.
You are correct. His gears are fine.
