blazen244 Posted February 18, 2009 Report Share Posted February 18, 2009 Can some body tell me why the cam cover gasket on these cars are such a hair raising issue for mechanics are they that bad, and how many have changed your own Link to comment Share on other sites More sharing options...
Chilled man Posted February 18, 2009 Report Share Posted February 18, 2009 ? becuase there isnt one its a rolled on out of a tube, you bolt everything together and you go . doesnt get much simpler thent that , just have to make sure you have a clean surface :D Link to comment Share on other sites More sharing options...
Rsterns Posted February 18, 2009 Report Share Posted February 18, 2009 Can some body tell me why the cam cover gasket on these cars are such a hair raising issue for mechanics are they that bad, and how many have changed your ownAs Chillman stated correctly, there isn't one....I think the issue for mechanics is, if they don't know of alternate sources for the tube of gue, and price it at Volvo, it's like $25 a tube. (A price guestimate). Also if you don't apply it correctly, it will leak! Done correctly and you will not have an issue. The stuff actually works very well. Link to comment Share on other sites More sharing options...
blazen244 Posted February 18, 2009 Author Report Share Posted February 18, 2009 So there is no gasket between the cover and the block wow, so how do it go bad and how do you prevent oil leaks :huh: Link to comment Share on other sites More sharing options...
Chilled man Posted February 18, 2009 Report Share Posted February 18, 2009 eventually the seal sometimes goes bad. if it does just pop the cover sand down each side allittle apply new volvo pink stuff and go Link to comment Share on other sites More sharing options...
Rsterns Posted February 18, 2009 Report Share Posted February 18, 2009 So there is no gasket between the cover and the block wow, so how do it go bad and how do you prevent oil leaks The gasket compound is a type that cures with the absence of air. IF you clean the mating surfaces COMPLETELY, and apply the compound with a short hair roller as required, and keep it out of the oil channels, once torqued into place, the compound will set, and you will not have leaks for your efforts. The only leaks I've ever encountered were due to improper application. Link to comment Share on other sites More sharing options...
blazen244 Posted February 18, 2009 Author Report Share Posted February 18, 2009 Ok have any of you done your own and do I have to remove anything involving the cam gears and cams, thanks for the visual aid shines some light, but that motor looks pretty bare Link to comment Share on other sites More sharing options...
Chilled man Posted February 18, 2009 Report Share Posted February 18, 2009 nope never done a single one myself ............. :lol: Link to comment Share on other sites More sharing options...
Rsterns Posted February 18, 2009 Report Share Posted February 18, 2009 nope never done a single one myself ............. LOL ...No I'd say that you probably do them two or three at a time, unless you were talking about a single cam! :lol: Link to comment Share on other sites More sharing options...
blazen244 Posted February 18, 2009 Author Report Share Posted February 18, 2009 ;) Ok any idea what kind of $$ I'll be spending I also need the PCV system changed, my car is in need of some TLC body looks great but it do a lot of sitting we don't have to drive it to working or anything it's the second car and I drive a company vehical. So is this worth getting repaired or should leaave it alone one mechanic say I should get a new car Link to comment Share on other sites More sharing options...
Rsterns Posted February 18, 2009 Report Share Posted February 18, 2009 Ok any idea what kind of $$ I'll be spending I also need the PCV system changed, my car is in need of some TLC body looks great but it do a lot of sitting we don't have to drive it to working or anything it's the second car and I drive a company vehical. So is this worth getting repaired or should leaave it alone one mechanic say I should get a new carHow bad is it leaking, and what are your mechanical abilities? Are you sure the leak isn't from one of the front or rear cam seals? (a total of four) Link to comment Share on other sites More sharing options...
Chilled man Posted February 18, 2009 Report Share Posted February 18, 2009 :lol: Pics Color milagecondition turbo or not Hi Actually any half retard mech should be albe to do it all with in two days if not quicker depending how knowledgalbe they are with volvos. The PCV is really easy 2hrs tops Redoing the cam cover seal I think is easier then doing the PCV since nothing really needs to come off the engine itself. But hey I am within driving distance and could use the extra money ................. Link to comment Share on other sites More sharing options...
Chilled man Posted February 19, 2009 Report Share Posted February 19, 2009 How bad is it leaking, and what are your mechanical abilities? Are you sure the leak isn't from one of the front or rear cam seals? (a total of four)agreed I would doubt its the head thats actaully leaking and the cam seals themselves since if hes looking to have the PCV done ..................is what is probally leaking Link to comment Share on other sites More sharing options...
blazen244 Posted February 19, 2009 Author Report Share Posted February 19, 2009 95' 850 Turbo motors condition is, it runs solid other than the oil leak and it's bad not a minor leak I was also advised that the main seal may possibly need to be serviced sometime in the near future I've had the car since 98' and it has a little over 200,000 miles on it need some suspention work in the front I have all that springs sway bar links seats and struts.The two mechanics I took it to didn't mention anything about the front or rear cam seals needing to be changed, so because it's not an everyday driver I want to tackle the biggest problem first which is the gasket Link to comment Share on other sites More sharing options...
blazen244 Posted February 19, 2009 Author Report Share Posted February 19, 2009 Hey I'm all for it just point me in your direction and let me know what you'll charge me I'll be glad to help and pay I just don't want to give up thecar inspite of the work needed I have time cause It don't get driven everydayHave to go I'll jump back on in bout an hour Link to comment Share on other sites More sharing options...
