wiggles Posted March 8, 2009 Report Share Posted March 8, 2009 I have the premium sound system, trying to tap off the rear speaker line to provide speaker-level input to a mono-block amplifier and run a JL w3 10" sub.So far I have been unsuccessful in even seeing the wire or how it reaches the rear dash and to the drivers.Presumably many of you have been through something similar to this, just looking for insight as to how they are run.Thanks! Link to comment Share on other sites More sharing options...
Young Burnsy Posted March 8, 2009 Report Share Posted March 8, 2009 Yeah I did this exact thing.Pretty simple all you have to do is pull the rear deck off and splice into the rear deck speakers.Your problem is that you don't know how to take off the rear deck? Link to comment Share on other sites More sharing options...
wiggles Posted March 8, 2009 Author Report Share Posted March 8, 2009 Yeah I did this exact thing.Pretty simple all you have to do is pull the rear deck off and splice into the rear deck speakers.Your problem is that you don't know how to take off the rear deck?Sounds like that's the case - I was hoping it would be easier then having to take the rear deck off. Link to comment Share on other sites More sharing options...
Young Burnsy Posted March 8, 2009 Report Share Posted March 8, 2009 Sounds like that's the case - I was hoping it would be easier then having to take the rear deck off.No but its really not hard to take the rear deck off either. you Just have to put down the seat. Remove the side bolsters from the sides of the back seat. Then pop off the part of the C pillar cover where it says 'SIPS airbag' or what ever and underneath that is a T20 screw. Remove those covers from each side and then you should be able to slide the rear deck panel forward.Lemme know if you need more help. Link to comment Share on other sites More sharing options...
wiggles Posted March 8, 2009 Author Report Share Posted March 8, 2009 No but its really not hard to take the rear deck off either. you Just have to put down the seat. Remove the side bolsters from the sides of the back seat. Then pop off the part of the C pillar cover where it says 'SIPS airbag' or what ever and underneath that is a T20 screw. Remove those covers from each side and then you should be able to slide the rear deck panel forward.Lemme know if you need more help.Thanks, I will be taking a look momentarily! Link to comment Share on other sites More sharing options...
