Guest Guest_whe6311_* Posted March 9, 2009 Report Share Posted March 9, 2009 HiMy S70's ABS and Check Brake warning light triggered ON.At same time, I can feel that the car hesitate to move and sluggish for a few moments.When the warning lights went OFF, the car back to normal, can drive smoothly.Do ABS failure & brake circuit problem directly affect engine performance? (I guess it only affect braking..)At first I thought the auto gearbox is going to failWhats the preoblem?Thank u Link to comment Share on other sites More sharing options...
Kibim Posted March 9, 2009 Report Share Posted March 9, 2009 Check your brake fluid level. If its too low, your ABS will not work. Link to comment Share on other sites More sharing options...
PsychoWagon Posted March 9, 2009 Report Share Posted March 9, 2009 Limp mode? Possible CAN network problem.Check your DTCs. Link to comment Share on other sites More sharing options...
Dan A Posted March 10, 2009 Report Share Posted March 10, 2009 did the flashing arrow light come on? if so, that's typical of abs module going bad and would cause your car to be slow from a dead stop (starting off in 2nd gear). Link to comment Share on other sites More sharing options...
PsychoWagon Posted March 10, 2009 Report Share Posted March 10, 2009 flashing arrow is transmission related, but as stated if it's a CAN problem it could trigger the TCM to go offline = limp mode.Since no one here is getting DTCs printed off from the dealer and want easy answers? Buy a $600 module and put it in as it is "most likely" the failed part, if not come back. Link to comment Share on other sites More sharing options...
Dan A Posted March 10, 2009 Report Share Posted March 10, 2009 flashing arrow is transmission related, but as stated if it's a CAN problem it could trigger the TCM to go offline = limp mode.Since no one here is getting DTCs printed off from the dealer and want easy answers? Buy a $600 module and put it in as it is "most likely" the failed part, if not come back.ABS module can cause the flashing arrow. Not sure if you were agreeing with me or not. And if it is the module, which is pretty hard to tell from the OPs description, but I'm reading in to it that it might be, then a rebuilt ABS module for around $150 or less is the ticket, not a new one for 4x the amount. Link to comment Share on other sites More sharing options...
PsychoWagon Posted March 10, 2009 Report Share Posted March 10, 2009 I was agreeing with you... just trying to explain why it would go on... I know didn't come accross that way. Would definitely like to see the DTC printout though. Make sure you tell them not to erase anything and that you don't want it diagnosed, just the print outs. Lots of dealerships have people who have no idea what they're doing when it comes to CAN diagnostics... so tehy erase the codes and say ---no fault found and print off the erased sheet So get a print out and post it and maybe we can be of more assistance. (You do need VIDA/VADIS to get a proper printout) Link to comment Share on other sites More sharing options...
