'00 V70r M66 Teaser
94850tx
It may fit and be working now but it won't work the reverse of how you have it (5sp auto axle into 4sp auto) and I doubt volvo changed it just for fun. Pull them out and set them side by side.
You did the opposite of what we had to over come.
  • Replies 174
wait yours is a 99 ? :huh:
:lol: damn it justin again you fail
So then wtf is the problem ?
I swapped 99 axles into a 00 car ?
...................edit.....................................
and no nick fails I stated that about 4 times exaclty what I did and didnt have a single issue .
poped them out of the 99 and poped them in on the 00
mine were exaclty the same
reason I am asking maybe I can help you guys figure out what your problem is since I havent had a single one ...
thats it
also who care of the 4speed/ 5speed deal you put it into a M66 wich 6 speed manual
hussein 98 axles in his m66 I have used 99 and 00 axles in my 98 so thats m56
the 01 axle ends to the tranny are the same as the 850 ones and S/V/C70
the wheel side there just slightly longer after the bearing area that they attached to the engine.
so ?
I am only trying to help that is it .
I had a issue with axles that I got from waltrip but they werent OEM axles they didnt fit right , I got napa axles ones and they slide right in .
again only trying to help you guys out
I swapped over on my 98R to the 99 style hubs only issue is the abs sensor / speed sensor
I need to rewire newer style in since the spots were the sensors go are different, other than that it bolts right in .
Looks like the CV's are larger '99? That's certainly not a bad thing. What's the deal with the sensor? The '98 won't fit in the '99 hub due to shape/style, or just harness length? I'll have to look at that. If the '99's are more substantial, maybe I'll swap out mine, can't hurt. Actually, probably won't since I have to sell my baby.. :(
the senosr wont fit since the 98sensor is larger then the 99 one
so you would have to drill out the 99 hub for it to fit other then that cake.
also the 99 sensors have the plug up in the engien bay where the 98s are right at the hub so you will have to cut wires regardless.
Nick can give me the ok to disclose anytime... just figured that it would be easier if I did all the thread at once whenever nick wants.
the proplem does not stem from an aftermarket halfshaft being funny.
in fact I dont believe that the problem with the halfshaft has anything to do with the halfshaft at all...
I'd rather not disclose until it's all said and done.
Justin you are confused.
An '00 5sp auto axle will not fully lock into a 4sp auto or manual tranny. Nuff said. If you can't set two side by side and figure it out from that statement I dunno how to help you understand. You put a 4sp axle into a 5sp...which is the opposite of what we are talking about--try putting the 5sp auto into a 4sp auto or manual- it doesn't fully lock. Aaron tried it, we have pics to show it. Of course simple solution on drivers side, not so simple on passenger. I am not posting everything just yet until we have several thousand miles on the car and I do more research via the parts catalog to find out the full story on what does and does not work. I am not going to post misinformation until I research further to find out specifically what cars/applications this applies to...hell I may never even post if for that reason since it may not be able to be determined.
My car has/had/has all OEM axles in it. There are some VIN splits on this stuff so it is possible my car is different from your '00R but I'd put money yours have the same slight difference mine had if you look carefully
? what ever it works for me not sure why you guys are having a hard time .
You are not talking about what we are. Try putting your '00 shaft into the 4sp. Won't stay in if you drive the car. The shaft that goes into the transmission is not as long. I'm not trying to be rude but your are not talking about the same swap around.
All the same ???...'00 is in the middle. Same issue on passenger side. Start comparing axles on pass side and it gets more complicated and S60R carrier bearing is in a different location...
I know everyone is thinking it's not that hard of an issue to get around...we all thought the same thing but it actually took a considerable amount of time to sort out on the passenger side.
ahh see that is what I was looking for .
hmmm my 99 and my 00 must be one late moddle and one early modle since I just swaped and went .
top ones from a 98
I figured that picture would help the most.
That is possible or like I said I think swapping the 99 into the 00 will work but 00 into 99 won't...
Hope you see what we were talking about, wasn't trying to be rude but it's difficult to understand without photos...and the passenger side is another animal that I'm not even going to get into now.
BTW Just dropped several more bills on something new and unique for the rear of the car...pics to come later...all of it due to Aaron's awesomeness
agreed . I see what your saying now for some reason volvo likes to play silly games
actually I dont think its the years that acutally matter its more wich axle did they use and wich one is there the same from another car.
considering the 93 car is the same frame and engien and body as a 00
just have less of a selection of cars to pull from in 99/00
If you look at the 98 axle at the top its the same axle and dimensions as the bottome one minsu the hub connection
so when I did mine from 99 into my 98 I got lucky with the right ones and the same deal with the 99 into the 00
