Kibim Posted March 17, 2009 Report Share Posted March 17, 2009 Looks like i'll be getting a BBK on the R soonish, wondering if the current 302mm slotted rotors will fit on the XC. Everything looks the same? Link to comment Share on other sites More sharing options...
NEU Posted March 17, 2009 Report Share Posted March 17, 2009 Well, I can't bolt up a P2 R caliper to my '00R, I doubt you could bolt up the older R caliper to a newer P2 car, with out making an adapter bracket. You could bolt newer P2 R calipers to your P2 XC, that would be 330mm. Link to comment Share on other sites More sharing options...
Kibim Posted March 17, 2009 Author Report Share Posted March 17, 2009 and probably wouldn't fit under the 16" rims. Not interested in swapping calipers, just the disks. I'll have to take everything apart 'n see. Link to comment Share on other sites More sharing options...
NEU Posted March 17, 2009 Report Share Posted March 17, 2009 I don't see how that would work if your XC disks are smaller then the 302 without adaptor brackets to push them out further. Def not a bolt up job, little bit more fabrication involved with that. Link to comment Share on other sites More sharing options...
Kibim Posted March 17, 2009 Author Report Share Posted March 17, 2009 I'm not sure what they are. I know the C70s etc came with 302s, as did the R. I'll just have to measure it up. Link to comment Share on other sites More sharing options...
NEU Posted March 17, 2009 Report Share Posted March 17, 2009 '99-'00 v70R had 302, I know that... Not sure about '98 s70R. :huh: Link to comment Share on other sites More sharing options...
MrWinkey Posted March 18, 2009 Report Share Posted March 18, 2009 XC what? 70/90? Link to comment Share on other sites More sharing options...
Kibim Posted March 18, 2009 Author Report Share Posted March 18, 2009 '01 V70XC AWD, and i know my S70 is running 302mm rotors up front. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted March 18, 2009 Report Share Posted March 18, 2009 There are 2 brake sizes for the P2 cars. Look at the min spec on the rotor, if it's 25mm you have the big ones. Link to comment Share on other sites More sharing options...
MrWinkey Posted March 18, 2009 Report Share Posted March 18, 2009 There are 2 brake sizes for the P2 cars. Look at the min spec on the rotor, if it's 25mm you have the big ones.That's what I do..however if they are aftermarket or you cannot find the stamping(which is on the hub of the rotor) you can remove the rotor and measure it ,,,,,11.25" is the standard and 12" across are the big ones Link to comment Share on other sites More sharing options...
