Matts 850 GLT Posted March 24, 2009 Report Share Posted March 24, 2009 Okay.so before I pull my head off can someone tell me if this amount of oil is normal/acceptable or are there serious issues with my motor?ThanksMatt Link to comment Share on other sites More sharing options...
StylinMotors Posted March 24, 2009 Report Share Posted March 24, 2009 Some oil is normal, but it should not be leaking out. Chances are you need to flush your intercooler. There is a plug on the bottom similar to a radiato plug. unhook all the hoses, remove the plug and flush with lots of good degreasing soap and water. You might want to do the same with all the hoses and pipes. This should help. Maybe look at new hoses as well. Link to comment Share on other sites More sharing options...
CO.T5M Posted March 24, 2009 Report Share Posted March 24, 2009 i would also check your PTC inlet on the intake hose and make sure that its not clogged and also make sure the turbo is not leaking. i had the same problem and it was the turbo. Link to comment Share on other sites More sharing options...
Yellow95 Posted March 24, 2009 Report Share Posted March 24, 2009 From your pic, I would say dont worry about it at all. Looks like every other 10+ year old volvo stock hoses I have seen. If it bothers you, get the stylin kit. Those hoses look a little long in the tooth.Gary Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted March 24, 2009 Author Report Share Posted March 24, 2009 i would also check your PTC inlet on the intake hose and make sure that its not clogged and also make sure the turbo is not leaking. i had the same problem and it was the turbo.Thanks, how do I check the turbo for leaking? Matt Link to comment Share on other sites More sharing options...
