bum2kev Posted March 28, 2009 Report Share Posted March 28, 2009 if you know something else please state it and ill add it to the list. Parts needed for front end conversion: Hood Fenders Fender Liners Headerpanel Bumper support Bumper Headlights Blinkers Grill Extras: Doors (door trim is different iirc) Steering wheel Front Seats Rear seats 98 Speedo Cluster (into 96-97 only) Headliner Map lights Dash (needs trimming) Door Handles (drivers handle needs lots of modification to get 850 key to work, use front passenger handle) V70 Upper/lower rear tails XC70 Rear bumper with dual outlet non x70 stuff: 960 steering wheel. 99-? Updated oil pan with built in oil cooler parts needed.. oil pan oil cooler oil pickup (in pan) Water pipe/block pipe 9186281 oil feed line to turbo. (stock one runs into water pipe) 8642560 oring 8642559 oring 30637339 oring x2 1236119 gasket for water pipe to head 9496493,9496492 water hoses for oil cooler Swapping 93-98 to 99+ accessories: 99+ Accessory rack Power Steering pump Alternator AC compressor Water res/PS res Bracket from strut tower Water res PS res Power steering drain line from PS pump Power steering lines (99-00 use the same racks as 93-98) Without AC 1270598 Bracket 9458470 Idler Roller 9125572 Ilder bolt cover 982821 Bolt 9458469 Belt Link to comment Share on other sites More sharing options...
PsychoBeano Posted March 31, 2009 Report Share Posted March 31, 2009 For the front end conversion you can use the 850 fender liners but I believe you will have to redrill them. Eyeing them over they looked different but I didnt make sure. I just used the x70 ones. Link to comment Share on other sites More sharing options...
Fake-R Posted April 1, 2009 Report Share Posted April 1, 2009 Rear seats work. I've got them. Link to comment Share on other sites More sharing options...
RBoy8 Posted April 1, 2009 Report Share Posted April 1, 2009 If you choose to convert to the x70 front end, is it possible to have working headlamp wipers? Link to comment Share on other sites More sharing options...
--Aaron-- Posted April 1, 2009 Report Share Posted April 1, 2009 If you choose to convert to the x70 front end, is it possible to have working headlamp wipers?I wouldn't see why not, you're already swapping the core support which houses the motors.... Link to comment Share on other sites More sharing options...
Fishey Posted April 2, 2009 Report Share Posted April 2, 2009 Here is a better ideaGo buy the car you want in the first place-Your PalFishey Link to comment Share on other sites More sharing options...
quiksilver Posted April 2, 2009 Report Share Posted April 2, 2009 Upper rear tails. Link to comment Share on other sites More sharing options...
prasamin Posted April 2, 2009 Report Share Posted April 2, 2009 front end you also need the grill! Link to comment Share on other sites More sharing options...
bum2kev Posted April 2, 2009 Author Report Share Posted April 2, 2009 ok i added and changed a few.anyone else? Link to comment Share on other sites More sharing options...
Dave 54 Posted April 2, 2009 Report Share Posted April 2, 2009 Rear tails, while not highly noticable the 850 and v70 edges are slightly different, the 850 are slightly more beveled than the v70, at least the one's I got. I left my lowers and swapped the uppers as like I said it's hardly noticeable, but there is a suttle difference. Link to comment Share on other sites More sharing options...
jordanvw Posted April 3, 2009 Report Share Posted April 3, 2009 what is this a list of all the 70 series stuff that will work on a 850? if it is, you missed alot of things Link to comment Share on other sites More sharing options...
bum2kev Posted November 14, 2009 Author Report Share Posted November 14, 2009 ok so i requested that this be reopened as i had a few more things to add and some questions. 1. converting a 94-98 850/x70 series to the 99 power steering rack/pump/reservoir setup a. what else is needed? accessory bracket? or can the pump just bolt right on? 99 subframe needed? different control arms? ect. i think thats it for now... Link to comment Share on other sites More sharing options...
Jaxx Posted November 14, 2009 Report Share Posted November 14, 2009 i'll add that for the wagons you need the rear door because of the 3rd brake light. Can't remember about sedans. Link to comment Share on other sites More sharing options...
MyCarIsRed Posted November 14, 2009 Report Share Posted November 14, 2009 i'll add that for the wagons you need the rear door because of the 3rd brake light. Can't remember about sedans. no... you just need some trim pieces, the light and the control module under the floor. Tailgate swap is 100% overkill, everything will swap over. Link to comment Share on other sites More sharing options...
z31jaime Posted November 14, 2009 Report Share Posted November 14, 2009 For the front end conversion you can use the 850 fender liners but I believe you will have to redrill them. Eyeing them over they looked different but I didnt make sure. I just used the x70 ones. v70 from trims fit fine in my 850. took a little work but they went in without re drilling. Link to comment Share on other sites More sharing options...
