turbor850 Posted April 1, 2009 Report Share Posted April 1, 2009 If you go from dual mass flywheel to single mass flywheel, what parts would be required and what would be a good alternative to the "R" clutch ?Any help of part numbers and what is needed would be great.I assume I need a 707 pressureplate from Audi and either "R" clutch or something to hold around 400 hp . . . . and would that be all ? ? ? Link to comment Share on other sites More sharing options...
Chilled man Posted April 1, 2009 Report Share Posted April 1, 2009 If you go from dual mass flywheel to single mass flywheel, what parts would be required and what would be a good alternative to the "R" clutch ?Any help of part numbers and what is needed would be great.I assume I need a 707 pressureplate from Audi and either "R" clutch or something to hold around 400 hp . . . . and would that be all ? ? ?just buy a single mass wheel thats it new $230 ish used $100 ? only alt to a R clutch is the 707 Link to comment Share on other sites More sharing options...
turbor850 Posted April 1, 2009 Author Report Share Posted April 1, 2009 just buy a single mass wheel thats it new $230 ish used $100 ? only alt to a R clutch is the 707what if I already got a Southbend stage 4 clutch in the car ? can that just work with the single mass wheel ? Link to comment Share on other sites More sharing options...
EricF Posted April 1, 2009 Report Share Posted April 1, 2009 Depends on thickness of the friction plates primarily I think. If the single mass and dual mass use the same clutch discs, then yeah you can probably just change flywheel and PP. Link to comment Share on other sites More sharing options...
JoshV70 Posted April 1, 2009 Report Share Posted April 1, 2009 Here's the exact dual mass clutch setup on Matt's car:Here's the 707 plate and clutch I have for my single mass:Both items from Southbend. Link to comment Share on other sites More sharing options...
johnloves850's Posted April 1, 2009 Report Share Posted April 1, 2009 anybody have aluminum fly wheels with their m56's?i would love to get one for my swap eventually, if people have had any experience with them that is... Link to comment Share on other sites More sharing options...
turbor850 Posted April 1, 2009 Author Report Share Posted April 1, 2009 Here's the exact dual mass clutch setup on Matt's car:Here's the 707 plate and clutch I have for my single mass:Both items from Southbend.ah, very nice Joshdid you get the stage 4 clutch also ? what was that rated at ? and what was the process of getting your set-up ? Link to comment Share on other sites More sharing options...
JoshV70 Posted April 1, 2009 Report Share Posted April 1, 2009 ah, very nice Joshdid you get the stage 4 clutch also ? what was that rated at ? and what was the process of getting your set-up ?Not sure what "stage" I got. Just called Andy at Southbend and told him I wanted a Sachs 707 plate with a 6 puck "feramic" clutch. I had to repin my flywheel for the pressure plate which wasn't a big deal. Link to comment Share on other sites More sharing options...
Chilled man Posted April 1, 2009 Report Share Posted April 1, 2009 josh what all did that end up running total ? Link to comment Share on other sites More sharing options...
JoshV70 Posted April 1, 2009 Report Share Posted April 1, 2009 josh what all did that end up running total ?It's been awhile. Somewhere around $500? Link to comment Share on other sites More sharing options...
Chilled man Posted April 1, 2009 Report Share Posted April 1, 2009 It's been awhile. Somewhere around $500?that was the clutch and repining the fly wheel or ? Link to comment Share on other sites More sharing options...
JoshV70 Posted April 1, 2009 Report Share Posted April 1, 2009 Clutch kit. Link to comment Share on other sites More sharing options...
mAydAy Posted April 2, 2009 Report Share Posted April 2, 2009 Throwout bearing/clutch slave cylinder setups are different (in their OEM setup). The single mass cars ran an external slave cylinder that pushed a lever arm onto the throwout bearing. Dual mass cars ran an internal slave cylinder/throwout bearing assembly.That said, I'm not sure if it matters if you run an external slave cylinder with a dual mass flywheel, or an internal slave cylinder with a single mass flywheel, all I know is that it changed over with the flywheels. Link to comment Share on other sites More sharing options...
Carbon_R Posted April 3, 2009 Report Share Posted April 3, 2009 You can haz a single mass flywheel but you need to use a single mass design clutch.R clutch, SPEC or South bend. The dual mass pressure plate is different, I have a 99 tranny that was designed to run with a dual mass but I use the internal slave design, SPEC stage 3+ clutch for the T5R as listed on thier website and a single mass flywheel.Just make sure your flywheel has squares (new design flywheel) not holes (old style), I have the old style and misfires galore. Need to replace my flywheel to the new one. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted April 4, 2009 Report Share Posted April 4, 2009 You can haz a single mass flywheel but you need to use a single mass design clutch.R clutch, SPEC or South bend. The dual mass pressure plate is different, I have a 99 tranny that was designed to run with a dual mass but I use the internal slave design, SPEC stage 3+ clutch for the T5R as listed on thier website and a single mass flywheel.Just make sure your flywheel has squares (new design flywheel) not holes (old style), I have the old style and misfires galore. Need to replace my flywheel to the new one.Have you tried swapping crank sensors to the other style (longer vs. shorter)? Link to comment Share on other sites More sharing options...
